Page 1 of 5 1 2 3 4 5
70 Challenger T/A - Engine Detailing - Whats correct? #511121
10/30/09 12:47 AM
10/30/09 12:47 AM
Texas
bogusracer Offline OP
Texas
I need photos or a reference book on how to properly detail a 340 Six Pack engine.
items like how many ribs on the vacuum hoses for the 3x2 bbls, vacuum hose for distributor, Correct fuel filter, radiator overflow hose, windshield washer hose - how many ribs? Brake Booster & Master Cyl. are they painted black or cad plated? What do the correct valve covers look like and how hard are they to come by? What was the correct battery - Group 24 or 27? Did the left Exh. Manifold have the Manifold Gasket with the ntegral spark plug heat shield? Air Breather lid what decals and what locations?
Any and all photos would be appreciated.
Thanks Moparts members for your responses.
Bogusracer
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: bogusracer] #511122
10/30/09 01:00 AM
10/30/09 01:00 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have photos of some of that available to purchase, I will dig out the link to that thread here in a minute or three.
For the batteries both types were available, if you have your broadcast sheet, what are the F codes?
Edit;
Link with more info on photos;
https://board.moparts.org/ubbthreads/show...e=0#Post4348097
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: Alaskan_TA] #511123
10/30/09 02:38 AM
10/30/09 02:38 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Pictures of Troy's T/A someone took at Spring Fling 2008.
This was obviously taken with a flash so some thing may look glossier than in reality. Photographs have limitations.
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: autoxcuda] #511124
10/30/09 06:32 AM
10/30/09 06:32 AM
Land of 10,000 Lakes
44D6PAKCUDA Online content
44D6PAKCUDA  Online Content
What color should the oil dip stick handle/loop and dip stick tube be?
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: 44D6PAKCUDA] #511125
10/30/09 11:41 AM
10/30/09 11:41 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I would like to know where you can get the black plastic covers for the carbs like Troy has in his pic?
Joe
65 Barracuda
70 Challenger
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: 44D6PAKCUDA] #511126
10/31/09 09:20 AM
10/31/09 09:20 AM
Texas
Texas
Anyone who can answer this question above?
Bogusracer
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: autoxcuda] #511127
10/31/09 09:23 AM
10/31/09 09:23 AM
Texas
Texas
Thanks for posting the photo's they'll give me a good starting point for reference.
Bogusracer
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: Alaskan_TA] #511128
10/31/09 09:27 AM
10/31/09 09:27 AM
Texas
Texas
Barry,
Will be sending you paymwnt for the DVD disc.
Also do you know where you can get the correct drivers side Exhaust Manifold Gasket with the integral spark plug heat shield?
Bogusracer
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: bogusracer] #511129
10/31/09 10:54 AM
10/31/09 10:54 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
...Also do you know where you can get the correct drivers side Exhaust Manifold Gasket with the integral spark plug heat shield?
Bogusracer
Mopar Performance.
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: bogusracer] #511130
10/31/09 11:00 AM
10/31/09 11:00 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bogusracer
I don't think the handle is black on the car above by accident. It looks like the tube is engine color. You need to get Troy to answer the research behind it.
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: autoxcuda] #511131
10/31/09 12:47 PM
10/31/09 12:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Dipstick handle is black, tube is engine color.
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: Alaskan_TA] #511132
10/31/09 12:51 PM
10/31/09 12:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
One thing to keep in mind for anyone using photos of Troy's car for reference - it has N95.
If you do not have N95 then that breather setup will not be the same for your car.
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: Alaskan_TA] #511133
10/31/09 02:51 PM
10/31/09 02:51 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
340 dip sticks & tubes, along with engine end of the neg bat cables being painted or not are details that always bring controversey.
One thing for sure, the alternator on Troys car, while certainly nice, is not properly detailed.
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: ScottSmith_Harms] #511134
10/31/09 04:54 PM
10/31/09 04:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
.. One thing for sure, the alternator on Troys car, while certainly nice, is not properly detailed.
That's because Baldason rebuilt and OE detailed him one that didn't charge. I guess he missed that detail.
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: ScottSmith_Harms] #511135
10/31/09 08:34 PM
10/31/09 08:34 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Are those battery cable ends correct?
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: jrwoodjoe] #511136
11/01/09 03:23 PM
11/01/09 03:23 PM
cataclysm80 Offline
cataclysm80  Offline
Joe
It would be great to have a set of those so that I could display with the air cleaner off!
Tav
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: Steve340] #511137
11/01/09 07:22 PM
11/01/09 07:22 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Yes the car appears to be a California made car, at least I think so. Looking that the 3 nipple fitting in the passenger side valve cover. It has the vapor return line. I dont believe this starts on non California cars until 1971. At that time wasnt it on all cars?
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: gomangoRTSE] #511138
11/01/09 10:57 PM
11/01/09 10:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: DAYCLONA] #511139
11/01/09 11:01 PM
11/01/09 11:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
G-series drawing that has nothing to do with 1970 cars. The 1971 cars did not get built.
Also, posting watermarked photos from a website you do not own is a .
Re: 70 Challenger T/A - Engine Detailing - Whats correct? [Re: cataclysm80] #511140
11/01/09 11:02 PM
11/01/09 11:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
