Re: 70 Challenger T/A - Engine Detailing - Whats correct?
[Re: bogusracer]
#511122
10/30/09 01:00 AM
10/30/09 01:00 AM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I have photos of some of that available to purchase, I will dig out the link to that thread here in a minute or three. For the batteries both types were available, if you have your broadcast sheet, what are the F codes? Edit; Link with more info on photos; https://board.moparts.org/ubbthreads/show...e=0#Post4348097
[Re: 44D6PAKCUDA]
#511125
10/30/09 11:41 AM
10/30/09 11:41 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I would like to know where you can get the black plastic covers for the carbs like Troy has in his pic? Joe
65 Barracuda 70 Challenger
[Re: 44D6PAKCUDA]
#511126
10/31/09 09:20 AM
10/31/09 09:20 AM
Posts: 306 Texas
bogusracer
Texas
What color should the oil dip stick handle/loop and dip stick tube be?
Anyone who can answer this question above?
Bogusracer
[Re: bogusracer]
#511129
10/31/09 10:54 AM
10/31/09 10:54 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
...Also do you know where you can get the correct drivers side Exhaust Manifold Gasket with the integral spark plug heat shield?
Bogusracer
Mopar Performance.
[Re: bogusracer]
#511130
10/31/09 11:00 AM
10/31/09 11:00 AM
autoxcuda
So Cal
Bogusracer
I don't think the handle is black on the car above by accident. It looks like the tube is engine color. You need to get Troy to answer the research behind it.
[Re: jrwoodjoe]
#511136
11/01/09 03:23 PM
11/01/09 03:23 PM
Posts: 4,165 Florida
cataclysm80
Joe
It would be great to have a set of those so that I could display with the air cleaner off!
Tav
[Re: gomangoRTSE]
#511138
11/01/09 10:57 PM
11/01/09 10:57 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: cataclysm80]
#511140
11/01/09 11:02 PM
11/01/09 11:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: Alaskan_TA]
#511141
11/03/09 02:47 AM
11/03/09 02:47 AM
Posts: 306 Texas
bogusracer
Texas
G-series drawing that has nothing to do with 1970 cars. The 1971 cars did not get built.
Barry,
Wouldn't this be applicable to the N95 cars built after this engineering drawing date - since the 1970 N95 cars were what all 71 model cars got for emissions controls?
Also isn't the washer bottle on a 70 Model E-Body supposed to have a square corner. The one on the car looks like a 71 model?
Bogusracer
[Re: bogusracer]
#511148
11/05/09 03:09 PM
11/05/09 03:09 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
Barry,
Bogusracer
Yup - That is a '71 bottle, wrong battery cables, no paint on negative cable, spark plug wire holders or exhaust bolts...all minor things - easily corrected. Looks nice.
[Re: Troy]
#511151
11/05/09 08:37 PM
11/05/09 08:37 PM
FJ5_Fish
Ontario, Canada
yup - That is a '71 bottle, wrong battery cables, no paint on negative cable, spark plug wire holders or exhaust bolts...all minor things - easily corrected. Looks nice.
.......you might want to check your notes and try again because you just failed the "T/A 101" class.
Really?
The 1970 Washer Bottle is a one year only piece. I have seen plenty of early '71's with leftover 70 parts but I have never seen a '70 with '71 parts (from the factory) on them. The over the counter washer bottle replacement would have been the '71 style. After almost 40 years a replacement bottle would look like the right age. All '70 E-Bodies I have or have seen (Including all my T/A's and AAR's have the 70 style washer bottle.
Galino Groovy started the foolish myth that smallblock negative cables were not on the engine when painted...more BS. I have loads of proof that they were on and painted.
Wire holders - I have seen both ways but the paint did not stick well on those. Most I have had were painted.
I agree with others that stated an engine color dipstick tube and black handle - on a 70. The 69 340's tube and stick were painted Blue - engine color.
Misc. Stuff I have found...
The distrbutor hold-downs are copper plated.
The fuel pumps were painted on the engine.
The loose washer (found on many untouched cars) under the intake bolt (which have a captive washer) are brass or copper.
T/A's used Organosol on the cowl and fenders. The cowls were masked off and not free-hand as on other e-bodies.
Most Trans-Am (only) cars have 2 plugs in the floor similar to the rubber-steel plugs for the rear shock towers in the trunk but about half the diameter. I have never seen these on anything other than a Trans-Am car.
[Re: gtx6970]
#511152
11/06/09 12:50 AM
11/06/09 12:50 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Troy, BUT, I gotta question the battery cables. The positive cable has the common grey starter relay lead of the cable that's still avail today,,, Shouldn't it be a medium brown color and a dished lead ends .. If I'm wrong I apologies in advance
Hi Bill, hope all is well. Both the positive and the negative cables are repops and your correct about the colors. If you take a original positive cable and lay it up against a assembline cable....there is a big difference. As for the negative cable, they do look closer however I believe in late 70 and on, one of the big differences in the negative cable is the end that bolts up to the head. There is a large rubber block at the end. It is about 3/4 long, sticks up about 3/16 and it goes all the way around the cable.
Here is a good picture of what I'm talking about on a low milage T/A....
The funny thing is all of the original T/As that I have seen all had this negative cable (with the big end on it) AND it was not painted on the engine.
I have seen many 340 4 bbl engines where the negative was painted....why not on the T/As....I don't know.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: FJ5_Fish]
#511154
11/06/09 01:18 AM
11/06/09 01:18 AM
wate
I'm a stranger to these topics and normally don't comment but there are other corrections needed that I see on almost every restored E body. Seems like these just get perpetuated (I have a DVD for $3.98 if you want to know what that word means) So above experts with your diagrams, etc. why have you never commented on these details?? guess you want to get paid??? $16 for your piggy bank?? Can I just send you a DONATION in a white envelope? keep your DVD!
Wiper hose routing- return hose from reservoir always came back along the firewall, routed up through the black heavy firewall clip above the junction box, wrapped up and behind the wiper motor and then exited above the wiper motor through that small hole that's on the lip. I've seen this correctly done less than 5 times in years of looking at restored cars. What do you think that hole is for??
Heater hoses attached to inner fender??? that's fine for big blocks and small block A bodies, not cudas or challengers. small block E bodies heater hoses didn't attach to the inner fender. as I told a mopar car judge who pointed out my mistake of NOT attaching them to the inner fender, REFER TO THE SERVICE MANUAL, it's in there!! Why do you think the alternator bracket is so tall??
6 pak vaccuum hoses always S clipped to the fuel lines, all three of them. never see this correctly done. doesn't make sense to have the hoses flopping around?? they didn't!
engine wiring harness between alternator and horns always routed across and through the large black clip. again, can't have wires flopping around in there!
spark plug wire holders always painted, never white! Yikes!!!
I can't take anymore, back to my Mopar cave............
[Re: Troy]
#511155
11/06/09 01:19 AM
11/06/09 01:19 AM
Troy
West Coast, CA
Here is a picture of the bottle that came out of my car....to be honest with you I still have it somewhere.
[Re: Troy]
#511156
11/06/09 01:23 AM
11/06/09 01:23 AM
Troy
West Coast, CA
....here's a good one, I love this car!! This is a very low milage T/A that I saw at Carlisle a few years ago. Very original....only a few things ever changed on it. Check out the washer bottle!!
[Re: Troy]
#511157
11/06/09 01:24 AM
11/06/09 01:24 AM
Troy
West Coast, CA
....same car, check out the Negative battery cable.
[Re: wate]
#511159
11/06/09 01:42 AM
11/06/09 01:42 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
never
always
I picked out some bits of what you said. Never & always? So, were you actually there taking notes on every one of these cars as they were built? If so, why are you using "restored? cars for reference?
Some of us prefer using original cars for reference, but even then we know that cars were not always built exactly the same every time.
[Re: Alaskan_TA]
#511160
11/06/09 01:45 AM
11/06/09 01:45 AM
Troy
West Coast, CA
Here is the next one...
"Galino Groovy started the foolish myth that smallblock negative cables were not on the engine when painted...more BS. I have loads of proof that they were on and painted."
OK....where is the proof?? I'm not saying that all 340 engines did or did not have painted ends. What I personality believe is the negative cables that DO NOT have the big rubber ends got painted AND the ones with the exposed ends did get painted. The reason is the ones that had the exposed ends were prone to corrosion so they painted them. Do I have any proof of this...no, but it does make sense and this is what I have seen.
I can say this, I have never seen a painted cable with the big rubber end, AND I have never seen a cable without the big rubber end not painted. But I also never saw every car that was ever made so....
Check you photos and see what you come up with. Pictures help...
[Re: Troy]
#511161
11/06/09 01:53 AM
11/06/09 01:53 AM
Troy
West Coast, CA
....next...
"Wire holders - I have seen both ways but the paint did not stick well on those. Most I have had were painted.
I too have seen many of the wire holder painted, just not late 70 built cars out of Hamtramck. Here is a few fun photos...
[Re: Troy]
#511162
11/06/09 01:56 AM
11/06/09 01:56 AM
Troy
West Coast, CA
....here is a nice one, look at the original upper hose!!
[Re: Troy]
#511163
11/06/09 02:17 AM
11/06/09 02:17 AM
Troy
West Coast, CA
I'm going for a three fer!!
"The distributor hold-downs are copper plated." ....Yes, your correct about the copper plated hold down. Mine is plated (What photo did you see that on my car??) Can you and were WHY it is plated???
The loose washer (found on many untouched cars) under the intake bolt (which have a captive washer) are brass or copper" I'm sorry but I don't follow you on this one..
"The fuel pumps were painted on the engine." Fuel pumps were painted??? Not on the T/As that I have seen, I might be wrong but here is another picture.... Many of the big blocks were painted but I don't know about the small blocks.
[Re: Troy]
#511164
11/06/09 02:19 AM
11/06/09 02:19 AM
Troy
West Coast, CA
This is also a real cool car!! 2500 mile 70 or 71 Demon 340 car....unpainted fuel pump.
[Re: Troy]
#511165
11/06/09 02:24 AM
11/06/09 02:24 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Photo from 1970 of the 1970 McAllister Dodge T/A. Modified for drag racing? Yes. But look at these photos close.
[Re: Troy]
#511166
11/06/09 02:31 AM
11/06/09 02:31 AM
Troy
West Coast, CA
...ok Almost done.. "T/A's used Organosol on the cowl and fenders. The cowls were masked off and not free-hand as on other e-bodies.
I heard this too but when I sanded my original paint T/A down, it was not Organosol....there was no texture to it. The black was painted first and then the color. Here is two photos one of the inner fender black out and you can see that it is smooth....not Organosol...
[Re: Alaskan_TA]
#511167
11/06/09 02:31 AM
11/06/09 02:31 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Close up from the same photo. Spark plug wire looms? - No paint. Negative battery cable end? - No paint. Also, note how glossy the black is on the master cylinder. Most folks seem to think that was a semi-gloss. Interesting........ If anyone has arguments either way, please back them up with original photos from cars that still have original details intact. I would love to see what you have. Honest. Barry
[Re: Troy]
#511168
11/06/09 02:34 AM
11/06/09 02:34 AM
Troy
West Coast, CA
Here is a photo of the cowl. You can see how the yellow goes over the top of the back paint. Even in this photo it look like a smooth black paint.
[Re: Alaskan_TA]
#511170
11/06/09 02:53 AM
11/06/09 02:53 AM
Troy
West Coast, CA
And last but not least...
"Most Trans-Am (only) cars have 2 plugs in the floor similar to the rubber-steel plugs for the rear shock towers in the trunk but about half the diameter. I have never seen these on anything other than a Trans-Am car."
Not sure what your talking about here....I don't recall any trunk photos being shown. My trunk floor (and all the other sheet metal) in my car is original, nothing was ever replaced.
That should be it on that subject..
I will say this....I'm no expert when it comes to these cars or any other car but I do love them and respect them. Because of that I put alot of time into the researching them. I don't say things like "Always" "Never" and "Positively" because somebody will prove you wrong.
Jimmy and I started off on the wrong foot and I'm sorry for that. I had a bad day at work and I guess I popped off a little to quick so I'm sorry for calling you out.
Again I would like to thank Berry Washington (Alaskan TA) for all of his photos and knowledge. If anybody would like a CD that is FULL of photos of a VERY low milage T/A, just PM him, IT IS WORTH EVERY PENNY!!!
[Re: Troy]
#511171
11/06/09 02:59 AM
11/06/09 02:59 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Thanks Troy, but I gotta say..... No PMs. Email only (or snail mail for orders) I have PMs disabled because I like all my messages to go to one place. Barry
[Re: autoxcuda]
#511174
11/06/09 03:24 AM
11/06/09 03:24 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The SPD & VIN have very little to do with when they were really built, so that is anyone's guess. But, I can tell you that the low mile T/A did have four broadcast sheets in it, one was for a later car (if you go by the SPD & VIN). The SPD of the low miler is 406. The sheet for the other car is 407. The VIN numbers are over 2000 apart. The broadcast sheet sequence numbers are only 12 apart. So, for whatever reason, the cars were actually built VERY close together regardess of the SPD & VIN & what most folks seem to assume. It is a fascination of mine, I would like to know why they did it that way. The more folks that send in broadcast sheet info for 1970 Hamtramck cars, the better chance I have of figuring it out. Barry
[Re: Alaskan_TA]
#511175
11/06/09 03:30 AM
11/06/09 03:30 AM
autoxcuda
So Cal
Barry
Would car with close broadcast sheet sequence numbers be built close to each other??
[Re: Alaskan_TA]
#511177
11/06/09 03:44 AM
11/06/09 03:44 AM
autoxcuda
So Cal
I am pretty sure that is what I just said.
I thought so, but didn't want to assume that.
Do you think broadcast sheet sequence numbers are issued in flat out built order? Would it be in order per line or both lines inclusive?
[Re: Alaskan_TA]
#511180
11/06/09 08:40 AM
11/06/09 08:40 AM
Posts: 1,101 Ont, Canada
moparo
Ont, Canada
Barry
Love the photos you have. One thing which I noticed on the picture which you may be able to answer. The valve cover looks to be later with the raise circle in the front.
I just noticed the by pass hose is not painted on this engine also.
I will post pictures later of the neg bat, cable with the rubber cover paint on a low mile car.
This washer bottle thing is way out of hand I have a June built 70 cuda all orig. and it has the "70" bottle.
performancecarrestorations.com
[Re: Troy]
#511181
11/06/09 09:30 AM
11/06/09 09:30 AM
Posts: 2,304 WI
RestoRick
WI
Correct, the black was applied first, then masked off before the topcoat color. As Troy points out, you can see some bleed back of topcoat color under the masking. Non TA/AAR cars had the blackout applied after topcoat color.
As for the type of black... my belief is it was organisol. I have a perfect organisol sample on hand right now; it's a very fine texture, that can be easily mistaken for smooth especially if dirty & aged. Logic... AAR's were painted in the same sequence... however, the AAR also had the fender tops, door & quarter upper edges sprayed at the same time as the cowl & fender banding. Why would two different kinds of black be used?
The real dead give away to identify it is to clean it well and look close to see the metallic flecks.
Rick
[Re: Troy]
#511184
11/06/09 12:34 PM
11/06/09 12:34 PM
Posts: 2,304 WI
RestoRick
WI
Doing great Troy! Very possible... I haven't seen them all Funny how anytime words like "detailing, details, OE, etc." are in a thread subject, how fast the topic drifts!!
[Re: autoxcuda]
#511185
11/06/09 12:48 PM
11/06/09 12:48 PM
moparo
Ont, Canada
yes all before color was applied
[Re: moparo]
#511186
11/06/09 01:36 PM
11/06/09 01:36 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Not sure what you mean by "later"? It is a 1970 car & the photo was taken in 1970.
The low mile T/A has the same style.
Since more than one style of washer bottle was available, I am sure it was pretty random as to which one ended up on which car.
[Re: Alaskan_TA]
#511187
11/06/09 01:42 PM
11/06/09 01:42 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
On the blackout.... One of the engineering drawings states; "Apply blackout paint or organisol paint in areas indicated" This is no doubt why some of you have found original cars one way or the other.
[Re: moparo]
#511188
11/06/09 01:44 PM
11/06/09 01:44 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
With the exception of the rocker pinchweld area.
[Re: RestoRick]
#511189
12/04/09 03:19 PM
12/04/09 03:19 PM
Posts: 679 N. Dak.
RareTA
super street
super street
N. Dak.
Rick
I dissagree with the black first. This is the tear down of my T/A. You can see in this photo the yellow was first then the black. Download the pic and enlarge it.
[Re: RareTA]
#511190
12/05/09 02:36 PM
12/05/09 02:36 PM
Posts: 18,157 Mass
DAYCLONA
Mass
As with "mass production" of anything, cars, trucks, kids toys, etc,....there may be factory prints, procedures, etc, they all change as production gets underway, some are due to mistakes, some are due to "experimentation", or penny pinching as production is underway,...in the case of different blacks, for black outs,....might have run out of "that" paint that day, and substituted something else, or a certain procedure was done at another work station on the line and Gomer used the "wrong" paint, or what was substitued on purpose or accident ,....back in the day it was Human intervention/mistakes on the line, not robots programed with a set of perimeters
[Re: DAYCLONA]
#511191
02/26/15 10:58 AM
02/26/15 10:58 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Mike, This thread is a blast... Now that I have my own T/A, I'm discovering things... One of my latest detailing questions is the center carb vent and it's relationship with the breather on the pass. valve cover. I see in the picture above and your factory illustration, the 340 pictures had all three nipples; 1. air cleaner base 2. Carb float bowl vent 3. gas tank vent
I thought #3 was only for California Emissions cars in '70 and then bacame standard on all cars starting in '70. I have seen a lot of T/A's and AAR's and haven't seen many, if any, with the gas tank vent. If that's the case and it was only for California emissions, then a production T/A and AAR would have the breather with 2 nipples, both on top, not the bottom-smallest one for the gas tank vent line...
No?
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: Alaskan_TA]
#511194
02/27/15 01:39 AM
02/27/15 01:39 AM
hemi68charger
Houston, Tx
On the non-N95 cars the port on the middle carb was open to the atmosphere.
Get out of here !!!! Well, I would have never thought that.... Thanks Barry....
[Re: mopar346]
#511196
02/27/15 05:20 PM
02/27/15 05:20 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
The question I have been running through my mind is was there a stub hose attached or was it bare.
The one at Wellborn's has one and pictures of my car right out of the barn has none. I run with none and believe it correct.
Please define "right out of the barn", are we talking Hamtramck, MI in the spring of 1970? Or sometime later. As you know those will pull out quite easily sometimes.
[Re: mopar346]
#511198
02/28/15 12:30 AM
02/28/15 12:30 AM
hemi68charger
Houston, Tx
...The one at Wellborn's has one and pictures of my car right out of the barn has none. I run with none and believe it correct.
I'm supposed to talk to Tim tonight or this weekend, I'll ask him. Do you have any pictures of what you're talking about.
[Re: hemi68charger]
#511200
02/28/15 02:28 AM
02/28/15 02:28 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
This is on his blue TA, a survivor from all accounts.
Careful, your character's showing!
[Re: mopar346]
#511202
03/02/15 05:59 PM
03/02/15 05:59 PM
NANKET
northwest USA
Literally pulled out of a barn in South Georgia in the early-mid-80s, in a reasonable state of originality. There is some incorrect items in the pictures from then and it is known that the shortblock was replaced under warranty in 72 with a non-TA 340. By no means an absolute reference but a was a very original lowish-milage car. That is why I ask about the vent tube, I have seen both ways but most every car has some many incorrect items that I can point out that I have not found one I consider proof. Troy's in a N95 car and although I used it for many things in my restoration it is no good for that question. Barry's DVD is the closest to proof, it has no hose either. I believe no hose but I figured I would ask since I had all the experts tuned in.
Thanks, Kevin
Kevin, here we are again, this car was 15 years old with an engine change before you saw it. That is hardly proof positive that is was built that way. It doesn't prove it didn't come that way either, just no wat to know for sure when the timeline stops in the mid 80's.
[Re: NANKET]
#511203
03/02/15 11:43 PM
03/02/15 11:43 PM
mopar346
Thanks, Kevin
"By no means an absolute reference but a was a very original lowish-milage car. That is why I ask about the vent tube,"
Kinda what I said and again that is why I am asking, I have viewed very few truly original AARs. And most I say have inaccuracies that I can pick out and I'm no guru, so the rest is automatically suspect. So do you know the answer of have any pictures or original examples that will verify it one way or the other?
Thank you
