Converter question #510991
10/29/09 09:54 PM
10/29/09 09:54 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Seems that my converter is too tight or something is wrong with it. By that I mean as the tranny fluid heats up to operating temp, the idle drop when putting into first is like 300-400 RPM and I have to footbrake it to keep it running.
I've tried everything in setting up the timing and carb and it idles well when cool, but when she's hot the verter seems to bog the motor down.
Is there a way to test the converter still in the vehicle or to I have to tear it out to check it properly.
Oh ya, its a 8" 3500 stall TCI.
Re: Converter question [Re: Mofopar] #510992
10/30/09 03:19 PM
10/30/09 03:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Have you tried footbrake stalling the converter?
Most problems like this are engine tuneup related.
Re: Converter question [Re: John_Kunkel] #510993
10/30/09 08:17 PM
10/30/09 08:17 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
I have focused totally on the tune-up (mind you I'm learning as I go). I haven't tried footbrake stalling the converter. I'm guessing it should not stall out til the advertised RPM of 3500?
I locked out the timing at 34* and have about 1 1/4 turns out on the idle mix screws (1050 dominator).
Re: Converter question [Re: John_Kunkel] #510994
11/13/09 12:56 AM
11/13/09 12:56 AM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Couldn't stall the thing today. Got up as high as 3000 and it wouldn't go any higher (or stall) no matter how much gas I gave it.
So I left 100 of rubber on the road
Re: Converter question [Re: Mofopar] #510995
11/13/09 08:27 AM
11/13/09 08:27 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
It sounds like it's working right. Your engine size and output will also factor in on the stall.
Re: Converter question [Re: buildanother] #510996
11/13/09 04:30 PM
11/13/09 04:30 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
This will expose my level of beginner-ness (if it wasn't already obvious by now) but, I'm guessing now that the "stall" is the point at which the engine rpms stop increasing, not actually a stall where the motor dies. Is that right?
Re: Converter question [Re: Mofopar] #510997
11/13/09 06:52 PM
11/13/09 06:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, it's converter stall speed not engine stall speed.
