heat range plug for indy heads ? #510880
10/29/09 06:43 PM
10/29/09 06:43 PM
Vidor Texas
O
onyxba Offline OP
onyxba  Offline OP
O
Vidor Texas
Alright guy's 528 indy headed what heat range plug would y'all use with a ngk plug naturally aspirated. We are getting stingy, so far we 1.36 60 ft. I'am going to start shock setting changes this weekend to see if sixty foot will improve. WE are still foot braking at 2800 rpm, at 2911lbs. Any help will be appreciated. Thanks Brian W.
Re: heat range plug for indy heads ? [Re: onyxba] #510881
10/29/09 07:50 PM
10/29/09 07:50 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Depends on your compression. Mine is 11.5 and I run Autolite AR3911's.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: heat range plug for indy heads ? [Re: 67HEMI] #510882
10/29/09 07:59 PM
10/29/09 07:59 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
I use to run champion c-59's in -1's Now run NGK's 5671-11's In 13.1 flattop motor.
Re: heat range plug for indy heads ? [Re: onyxba] #510883
10/29/09 09:45 PM
10/29/09 09:45 PM
AndyF Offline
AndyF  Offline
Mancini Racing has a chart on their website and Indy has a chart in their catalog. Indy recommends the Champion racing plugs with the super short ground strap. That is what I started to use and they seem to work just fine.
Re: heat range plug for indy heads ? [Re: onyxba] #510884
10/29/09 10:16 PM
10/29/09 10:16 PM
Compression ratio and type of fuel(Alcholol, race gas and octane or pump gas?) would be helpful
Re: heat range plug for indy heads ? [Re: Cab_Burge] #510885
10/29/09 11:55 PM
10/29/09 11:55 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
AR 3933 for a 13:1+ on alky, and AR3934 for milder 11-12:1 engine on race fuel.
Re: heat range plug for indy heads ? [Re: Bob_Coomer] #510886
10/30/09 09:05 AM
10/30/09 09:05 AM
Las Cruces New Mexico
68post Offline
68post  Offline
5671-8 on alcohol works great
Re: heat range plug for indy heads ? [Re: Cab_Burge] #510887
10/30/09 09:20 AM
10/30/09 09:20 AM
Vidor Texas
O
onyxba Offline OP
onyxba  Offline OP
O
Vidor Texas
Compression is 11.5 to 1 flat top piston and using 110 race fuel.Thanks for the help. Brian W.
Re: heat range plug for indy heads ? [Re: onyxba] #510888
10/30/09 09:43 AM
10/30/09 09:43 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I have run the NGK R5672A-8's for a long time now and I can get them at advance for 2bucks a piece.
I am 12.8:1.
Re: heat range plug for indy heads ? [Re: RonP] #510889
10/30/09 09:46 AM
10/30/09 09:46 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Autolite racing AR3934 I get several seasons out of a set, and I change them out..But to be honest there is probably not much wrong with them.
Re: heat range plug for indy heads ? [Re: Bob_Coomer] #510890
10/30/09 11:12 AM
10/30/09 11:12 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Most of you guys must not be able to read. He ask for NGK numbers not Autolite not Champion. NGK 5671A-8
I get so sick of the guys that want to tell you about everything but what you ask about. Maybe there is a reason he ask about NGK. If you can't input anything about the asked question don't input anything. If you don't like my responce tuff shi$.
