Multiple Carb Adjustment tool?
#510587
10/29/09 09:03 AM
10/29/09 09:03 AM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
What does this do, what is it actually aligning? Its an Edelbrock #4025
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Multiple Carb Adjustment tool?
[Re: Pyper70]
#510588
10/29/09 09:33 AM
10/29/09 09:33 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Usually used on side draft carbs like on motor cylce or an MGB's SU style carb to Synch the carbs.
[Re: Challenger 1]
#510591
10/29/09 11:11 AM
10/29/09 11:11 AM
Pyper70
Athens, Greece
So this is essentially pointless to purchase for a dual quad setup then?
[Re: buildanother]
#510593
10/29/09 11:25 AM
10/29/09 11:25 AM
Posts: 4,848 Memphis
HemiRick
Memphis
It's made to measure flow thru a carb but it wont fit over a 4 bbl works only with 1 and 2 bbl carbs. I suppose you could make a larger base adapter and use it on a 4 bbl.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: ScottSmith_Harms]
#510598
10/29/09 01:23 PM
10/29/09 01:23 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Scott,
Why is there a Christmas tree on your roof, shouldnt you be picking up some candy or maybe a Turkey?
1971 Factory Appearing Duster 340 11.000 @ 122 mph
