Is It posible ? torque converter bench test #51035
12/31/07 12:07 AM
12/31/07 12:07 AM
Valencia, España
NachoRT74 Offline OP
Valencia, España
I know must be done ( if is posible ) at a tranny shop... but is posible ? I want to be sure if keep my stock converter OR the new MP I got and I'm trying to keep away from removing the tranny just to test both mounted.
thanks.
Nacho.
Re: Is It posible ? torque converter bench test [Re: NachoRT74] #51036
12/31/07 12:39 AM
12/31/07 12:39 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Mopar Action had a tech article on that a while ago. Check your back issues if you have them or see if it's on thier website.
Re: Is It posible ? torque converter bench test [Re: Neil] #51037
12/31/07 11:04 AM
12/31/07 11:04 AM
Valencia, España
Valencia, España
I don't buy magazines. Have a couple but that's all, and anyway they are hard to find here in Venezuela... just Chebbys and Phords are easy.
will check on website but will be great if somebody can help me anyway.
editing... made a search and found nothing
Re: Is It posible ? torque converter bench test [Re: NachoRT74] #51038
07/04/08 08:32 AM
07/04/08 08:32 AM
Auburn Mich.
5.7bob Offline
5.7bob  Offline
Auburn Mich.
Trying to track down a set of 64 try-y max wedge exhaust manifolds that where sold from the Toledo OH. area. Thanks BOB 1 989 662 6623
Re: Is It posible ? torque converter bench test [Re: 5.7bob] #51039
07/04/08 09:48 AM
07/04/08 09:48 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Get two long, flat screw drivers. Put one all the way in until you touch the bottom splines. It should turn freely forward and backwards. Now use that same screw driver and keep the lower spline from turning. Use the second screw driver and contact the splines above the lower one. The upper spline should only turn in one direction with no tight spots. if it turns both directions with the bottom spline locked, it's bad. If there is any rough feel to either splines while turning I wouldn't use it.
Re: Is It posible ? torque converter bench test [Re: NachoRT74] #51040
07/04/08 10:27 AM
07/04/08 10:27 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
thanks.
Nacho.
what EXACTLY do you want to test ?
Re: Is It posible ? torque converter bench test [Re: Neil] #51041
07/04/08 11:20 AM
07/04/08 11:20 AM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
Mopar Action june 2005
Re: Is It posible ? torque converter bench test [Re: bigslant6fan] #51042
07/04/08 11:47 AM
07/04/08 11:47 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
A tranny shop uses a dyno to test with. If they do any testing at all.
Re: Is It posible ? torque converter bench test [Re: 5.7bob] #51043
07/04/08 12:45 PM
07/04/08 12:45 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
sent you a PM 5.7 bob
Re: Is It posible ? torque converter bench test [Re: maxwedge1] #51044
07/04/08 10:08 PM
07/04/08 10:08 PM
Valencia, España
Valencia, España
wow, never thought this was to be floated on somehow from that long time ago
I was meaning stall test to know the stall on bench before mount
Re: Is It posible ? torque converter bench test [Re: NachoRT74] #51045
07/05/08 10:48 AM
07/05/08 10:48 AM
Grand Prairie,Texas
Grand Prairie,Texas
There's no way to test stall on the bench.
Re: Is It posible ? torque converter bench test [Re: NachoRT74] #51046
07/05/08 11:27 AM
07/05/08 11:27 AM
U.S.S.A.
U.S.S.A.
thats because someone turned it into a possibly succesful , wrong forum , WANT AD ...
