Wiper linkage bushing/attachment #510358
10/28/09 10:20 PM
10/28/09 10:20 PM
Missouri
convertriple Offline OP
super gas
super gas
Missouri
I'm having a HECK of a time getting the wiper linkage attached to the passenger side wiper. I have the wiper motor out, and can get my hand in there, but no luck getting the rod/bushing to snap onto the wiper pivot. I have tried pliers, hammer and extensions, etc
This is a 73 A-body which uses the plastic insert bushings.
Anyone know a trick to this?
Re: Wiper linkage bushing/attachment [Re: convertriple] #510359
10/28/09 10:43 PM
10/28/09 10:43 PM
IA
landon1 Offline
landon1  Offline
IA
i did that chore on my D100....i think you just gotta keep fighting it...
idk if it would work or not, but i put my front wheel bearing dust caps in the freezer for 5 minutes or so to get them to fit...not sure if plastic would contract like that or not
'71 Satellite Sebring 440
Re: Wiper linkage bushing/attachment [Re: convertriple] #510360
10/28/09 10:47 PM
10/28/09 10:47 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
I just did my 74 RR, with the plastic bushing.I learned to leave my wiper motor on the cars and unbolt the regulators and unhook off of wiper motor,and took regulators and shafts out in one piece. I put new bushings in rod and had to tap them on my regulators with a rubber mallet, they were a [Edited by Moparts - Family Friendly Site - Keep it clean], then i played with them for an hour getting them back in, but I got em, didn't cuse to much, then hooked up on wiper motor and they work prefect on all three speeds. After i got them on regulator i sprayed bushings with white lube,stuck back in as one unit,all hooked up, installing drivers side reg, first,then passenger, then to motor.
Re: Wiper linkage bushing/attachment [Re: 268RTs4ME] #510361
10/28/09 11:12 PM
10/28/09 11:12 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
just need to learn how to bend your forearm. and bleed a little. it can be done. hurts like hell- but it'll go on
Re: Wiper linkage bushing/attachment [Re: aarcuda] #510362
10/29/09 09:48 PM
10/29/09 09:48 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
I drill a 1/16" hole in the back of the bushing to let the air out.
Re: Wiper linkage bushing/attachment [Re: aarcuda] #510363
10/29/09 10:00 PM
10/29/09 10:00 PM
Missouri
super gas
super gas
Missouri
I've got the bleeding part down, I'm resisting teaching my forearm to bend though .
It's been a b****, it wouldn't be so bad, but it's an AC car, and there is apparently more stuff in the way than on my old non-AC car. I'm trying to do it through the wiper motor hole, hopefully I don't have to disassemble the entire undash section. That would sock.
I think I have replenished my vocabulary enough that I can give it another try this weekend.
I'll try the 1/16 hole as well.
Re: Wiper linkage bushing/attachment [Re: convertriple] #510364
10/29/09 10:14 PM
10/29/09 10:14 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Try a little white lithium grease inside the bushing.
Re: Wiper linkage bushing/attachment [Re: In_The_Pink] #510365
10/30/09 12:12 AM
10/30/09 12:12 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I did my 79 D100 last year, and I used the white grease, and I was able to get a tiny pair of channel lock pliers in there to put the final squeeze on it..
Re: Wiper linkage bushing/attachment [Re: convertriple] #510366
10/30/09 01:09 AM
10/30/09 01:09 AM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
I did mine a while back on my '70 Dart. If I remember right I ended up taking out the ashtray and radio and I was able to reach it thru the ashtray opening while looking thru the radio opening. Probably won't work though if you have forearms like Popeye.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Wiper linkage bushing/attachment [Re: MadMatt] #510367
10/31/09 02:11 PM
10/31/09 02:11 PM
Missouri
super gas
super gas
Missouri
Finally got it, I had tried every pair of plier/vice grips available EXCEPT the 24 inch pair. Guess what, I never thought they would fit, but they did the job. I still can't believe it.
Wipers work now!
Thanks for the help guys.
Re: Wiper linkage bushing/attachment [Re: 69MOPE] #510368
10/31/09 04:29 PM
10/31/09 04:29 PM
CHRGR69 Offline
CHRGR69  Offline
Hmmmmm
Grandma always said I had "hands of gold"!
