Is It posible ? torque converter bench test
#51035
12/31/07 12:07 AM
12/31/07 12:07 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I know must be done ( if is posible ) at a tranny shop... but is posible ? I want to be sure if keep my stock converter OR the new MP I got and I'm trying to keep away from removing the tranny just to test both mounted.
thanks. Nacho.
Re: Is It posible ? torque converter bench test
[Re: Neil]
#51037
12/31/07 11:04 AM
12/31/07 11:04 AM
NachoRT74
Valencia, España
I don't buy magazines. Have a couple but that's all, and anyway they are hard to find here in Venezuela... just Chebbys and Phords are easy. will check on website but will be great if somebody can help me anyway. editing... made a search and found nothing
[Re: 5.7bob]
#51039
07/04/08 09:48 AM
07/04/08 09:48 AM
Posts: 2,520 God's Country Maryland
GODSCOUNTRY340
Get two long, flat screw drivers. Put one all the way in until you touch the bottom splines. It should turn freely forward and backwards. Now use that same screw driver and keep the lower spline from turning. Use the second screw driver and contact the splines above the lower one. The upper spline should only turn in one direction with no tight spots. if it turns both directions with the bottom spline locked, it's bad. If there is any rough feel to either splines while turning I wouldn't use it.
[Re: NachoRT74]
#51040
07/04/08 10:27 AM
07/04/08 10:27 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
thanks. Nacho.
what EXACTLY do you want to test ?
[Re: 5.7bob]
#51043
07/04/08 12:45 PM
07/04/08 12:45 PM
Posts: 536 PA
maxwedge1
PA
[Re: maxwedge1]
#51044
07/04/08 10:08 PM
07/04/08 10:08 PM
NachoRT74
Valencia, España
wow, never thought this was to be floated on somehow from that long time ago
I was meaning stall test to know the stall on bench before mount
[Re: NachoRT74]
#51046
07/05/08 11:27 AM
07/05/08 11:27 AM
JohnRR
U.S.S.A.
thats because someone turned it into a possibly succesful , wrong forum , WANT AD ...
Trying to track down a set of 64 try-y max wedge exhaust manifolds that where sold from the Toledo OH. area. Thanks BOB 1 989 662 6623
