Re: lifting a hemi for trip to the dyno?
[Re: az426john]
#509678
10/28/09 10:11 AM
10/28/09 10:11 AM
Posts: 4,799 ILL
MLR426
ILL
You said your taking it to the dyno ? Why would you attach the trans ?? If your trying to transport it to the dyno then set the engine in a tire or mount it to a cart with casters.
logan426
[Re: mopar mike]
#509680
10/28/09 12:07 PM
10/28/09 12:07 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Mine came with and I used the single 4 bbl lifting plate on the intake....Works fine. You can also use the holes on the ends of the heads.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#509681
10/28/09 12:48 PM
10/28/09 12:48 PM
Posts: 4,799 ILL
MLR426
ILL
Yes to get it out use the corner end head bolt holes or use a lifting plate.
logan426
[Re: mopar mike]
#509686
10/28/09 09:10 PM
10/28/09 09:10 PM
Posts: 31,069 Oregon
AndyF
[Re: AndyF]
#509688
10/28/09 10:07 PM
10/28/09 10:07 PM
Posts: 228 Galveston,IN
jackel440
Galveston,IN
I make these engine lift plates for big blocks. I could make them Hemis also, just haven't ever done it. The plates bolt to the exhaust side of the heads and give you a very secure place to attach a chain.
Those are pretty sweet,but I had a manifold get bound up on a stud once and the whole water jacket and casting broke out of a perfectly good head.There wasn't that much pressure on it when it broke.I was sliding it off the studs by hand. So after my experiance i almost cringe at the thought of your big block hanging by the exhaust studs going into a thin water jacket. Nice job on the brackets though
[Re: AndyF]
#509690
10/28/09 10:54 PM
10/28/09 10:54 PM
Posts: 1,261 ILL
mark7171
ILL
Looks great, affordable?
