Indy 572-13 Problems
#509660
10/28/09 07:33 AM
10/28/09 07:33 AM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Has anyone seen or heard of there being water leak issues or head sealing issues with these heads? Or any other kind. Thanks Marty
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: Indy 572-13 Problems
[Re: W8n2DustU]
#509661
10/28/09 08:08 AM
10/28/09 08:08 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
elvis had to weld up an exhaust port. cnc made it very thin in one spot. also had to put smaller valves in the heads because they touched each other
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: W8n2DustU]
#509662
10/28/09 09:21 AM
10/28/09 09:21 AM
Posts: 1,283 Colorado,U.S.A
4404dart
Colorado,U.S.A
I bought my 572's used so not sure who ported them, but I had water in a couple cylinders and thought it was a head gasket, it turned out it was a hole from the water jacket into #6 intake port. I fixed it and went out to the last race, and the other head started leaking, I haven't fixed that one yet. They don't flow so great either.
[Re: 4404dart]
#509663
10/28/09 10:20 AM
10/28/09 10:20 AM
i have a feeling i know who ported them, same thing happened to mine on #6 as well. it sucked, mine let loose on the dyno.
#509664
10/28/09 01:57 PM
10/28/09 01:57 PM
Posts: 2,933 A shed in England
Tig
A shed in England
We kept loosing cylinder pressure on # 1 and getting water in there too. Turned out there was a low spot on the head nr the water hole a .020" skim cured it. Heads flow in the high 380's. Chamber work and a 4.50 bore help so I'm told.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: W8n2DustU]
#509665
10/28/09 03:57 PM
10/28/09 03:57 PM
are those leaky 572-13 heads hand ported?
[Re: Old School]
#509667
10/28/09 05:08 PM
10/28/09 05:08 PM
not cnc'd, it was a real hand job with a reach-around
[Re: Old School]
#509668
10/28/09 05:08 PM
10/28/09 05:08 PM
Tig
A shed in England
Numbers were @ .700, If I remember rightly no improvement above. The guy who ported them said he could probably get a little more at a higher lift but he expected that low / mid lift flow would be compromised. It was a while a go
#509669
10/28/09 08:39 PM
10/28/09 08:39 PM
4404dart
Colorado,U.S.A
Hi Dan, not sure if you were including me in this, but, they appear to be CNC ported and then smoothed by hand. The ports are very consistent. We think on mine anyway, that there was some porosity, and it is VERY thin. MPG head service does the machine work for me, and they do alot of engine masters work, and like Scott (owner) said, it's just a big dumb port. I have talked to others around here that have the same heads, and all have epoxied the floor to clean up the port. A lot of work and a lot of $. They tend to stall around .650 lift, and flow around 360 to 380 cfm, before stalling, and dropping.?? With all the water that went thru the engine, you would be surprized how well the pistons I got from you look, they're tuff as nails!
#509670
10/28/09 08:41 PM
10/28/09 08:41 PM
4404dart
Colorado,U.S.A
Ouch! Care to share,,,, who?
[Re: 4404dart]
#509671
10/28/09 08:54 PM
10/28/09 08:54 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
