What size front runners are you all running ? #509402
10/27/09 10:03 PM
10/27/09 10:03 PM
Wi.
65_gt_rag_402 Offline OP
Wi.
what size front runners are you guys running ? >>
26"-27"-28" ? what brand name? I have 25.25" up front now and it needs a taller tire so I can let the front end down lower. I need that 5 inch front end travel . have the new cal trac shocks up front and the complete cal trac set up in the rear also.
Thanks in advance
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: What size front runners are you all running ? [Re: 65_gt_rag_402] #509403
10/27/09 10:20 PM
10/27/09 10:20 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
I'm running 29" M/Ts on mine and love em...
Curtis
Taking over the World one win light at a time.
Re: What size front runners are you all running ? [Re: afxcoronet] #509404
10/27/09 10:24 PM
10/27/09 10:24 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I think their 27.5 M/T on the Duster....
Re: What size front runners are you all running ? [Re: 65_gt_rag_402] #509405
10/27/09 10:30 PM
10/27/09 10:30 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Hoosier 26"
Re: What size front runners are you all running ? [Re: B1KILLER] #509406
10/27/09 11:14 PM
10/27/09 11:14 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
26" goodyears here
Just keep in mind that as you increase the diameter you increase the rollout and it will slow your RT's.
Post deleted by Defbob [Re: WILD BILL] #509407
10/27/09 11:44 PM
10/27/09 11:44 PM
Re: What size front runners are you all running ? #509408
10/28/09 06:25 AM
10/28/09 06:25 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
26 here
Re: What size front runners are you all running ? [Re: Otherlane] #509409
10/28/09 06:57 AM
10/28/09 06:57 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
26 M/T with Cal-Tracs
Re: What size front runners are you all running ? [Re: b1dartsport] #509410
10/28/09 11:39 AM
10/28/09 11:39 AM
Az
Crizila Offline
Crizila  Offline
Az
If you are looking for a little more of a street / strip compromise and save a few $, you might want to consider an all aluminum wheel from a late 70's Cordoba. They might be a little wide at 15"X6", but they weigh 13# each without all the flash on them. I mounted 70 series street radial tires on mine (27.4" dia ) for a total weight (tire / wheel / lug nuts) of 41 lbs. each. Not too bad considering what the rest of my turd weighs.
Fastest 300
Re: What size front runners are you all running ? [Re: 65_gt_rag_402] #509411
10/28/09 11:50 AM
10/28/09 11:50 AM
Locomotion Offline
Locomotion  Offline
Hoosier 28" on my Dart Sport.
But I chose the size based on the reaction times I was getting when leaving on a comfy spot on the tree.
Re: What size front runners are you all running ? #509412
10/28/09 12:15 PM
10/28/09 12:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
23" Hoosiers...
I went BIG on mine to slow the reaction time down, I
went from a 22.5" to a big 24.5"
Re: What size front runners are you all running ? [Re: MR_P_BODY] #509413
10/28/09 01:07 PM
10/28/09 01:07 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Depending on what series we run (422 AllStars run a 0.400 full tree; the rest of the world runs a 0.500 full tree), we switch between 26.5 and 29" tires.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: What size front runners are you all running ? [Re: 65_gt_rag_402] #509414
10/28/09 01:31 PM
10/28/09 01:31 PM
an8sec70cuda Offline
28" tall M/T Sportsmans. I went with the 28" so I could do exactly what you're trying to do...get more suspension travel. I used to have 26" tires on it and put on the 28" tires. I lowered the car down over them for the same ride height but an extra inch of travel. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What size front runners are you all running ? [Re: an8sec70cuda] #509415
10/28/09 01:54 PM
10/28/09 01:54 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I haven't run them yet (other than about 1 mile on the street), but have 28" Moroso DS2s. I was a little disappointed in that they measure out at 27.5", because I wanted to do the same thing.
Re: What size front runners are you all running ? [Re: ZIPPY] #509416
10/29/09 08:21 PM
10/29/09 08:21 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Moroso 28" on the Coronet and 26" Hoosiers on the Duster.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: What size front runners are you all running ? [Re: 65_gt_rag_402] #509417
10/29/09 08:30 PM
10/29/09 08:30 PM
NC
barracuda man Offline
NC
Thanks in advance
I run the moroso ds 26"at 35psi.some tracks i race i need a 25"or 24" just to cut a light.
Re: What size front runners are you all running ? [Re: 65_gt_rag_402] #509418
10/29/09 08:56 PM
10/29/09 08:56 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Moroso 7.60 C 15 on '72 'Cuda. I had to clearence front fender just a little. With this size tire I can lower the torison bars all the way to the bump stops to get max travel and keep the oil pan safe. Tires are approx 29.5" on 3.5" wheel.
Brian Dunnigan
Re: What size front runners are you all running ? [Re: 65_gt_rag_402] #509419
10/29/09 09:37 PM
10/29/09 09:37 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Been using the Moroso 29's for 20 years,street driven over 3000 miles a year
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What size front runners are you all running ? [Re: hemi-itis] #509420
10/29/09 09:49 PM
10/29/09 09:49 PM
NC
NC
WoW! nice ride.Whats it run.
Re: What size front runners are you all running ? [Re: barracuda man] #509421
10/29/09 09:54 PM
10/29/09 09:54 PM
hemi-itis Offline
hemi-itis  Offline
I'm only allowed to go 10.0
