what size Accusump? #509389
10/27/09 09:57 PM
10/27/09 09:57 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
1 or 2 quart Accusump?
I shouldn't need a 3 quart... or should I?
just need it for pre-oiling a big block with drysump
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: what size Accusump? [Re: RylisPro] #509390
10/27/09 10:03 PM
10/27/09 10:03 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Don't know about dry sump but I got a 3 qt. on mine. Have he electric valve for pre-lube and hopefully don't ever need it for loss of pressure, but it's there if I do need it.
Re: what size Accusump? [Re: RylisPro] #509391
10/27/09 10:32 PM
10/27/09 10:32 PM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
You don't really need an accusump with a dry sump. If you're concerned with priming it, just take the belt off and spin it with an electric drill prior to initial startup. The dry sump's design doesn't necessitate an accusump.
Re: what size Accusump? [Re: Ben Holt] #509392
10/28/09 12:06 AM
10/28/09 12:06 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: what size Accusump? [Re: Ben Holt] #509393
10/28/09 12:54 AM
10/28/09 12:54 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
two problems with that:
1. my dry sump runs off the oil pump drive, so no belt
2. I am lazy
I agree, I don't really need it & don't want the extra weight
just a nice to have option
was just wondering if 1 quart of oil was enough to pre-oil a big block
thanks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: what size Accusump? [Re: go green] #509394
10/28/09 12:57 AM
10/28/09 12:57 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
At least 2, 3 if you have space. I know on the Morosos, you won't get 3qt in the 3qt Accusump. More like 2 1/2 depending on how much air pressure charge you use and how much engine oil pressure is. I like them, put the electric valve on it if it doesn't come with one.
Post deleted by Defbob [Re: CMcAllister] #509395
10/28/09 02:15 AM
10/28/09 02:15 AM
Re: what size Accusump? #509396
10/28/09 02:49 AM
10/28/09 02:49 AM
I put a 3qt. on mine with an electric switch..It works great
Post deleted by Defbob [Re: RylisPro] #509397
10/28/09 05:38 AM
10/28/09 05:38 AM
Re: what size Accusump? [Re: RylisPro] #509398
10/28/09 07:13 PM
10/28/09 07:13 PM
snook Offline
snook  Offline
You have a PM
Re: what size Accusump? #509399
10/28/09 10:36 PM
10/28/09 10:36 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Have you decided on a oil heater yet ?
nope haven't thought that far yet...
can you recommend one?
warm oil, cold coolant right?
how are you achieveing that with the Evans stuff?
I'll let you know about the fiberglass stuff too
thanks Fred,
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: what size Accusump? [Re: RylisPro] #509400
10/28/09 10:56 PM
10/28/09 10:56 PM
I just sold a three quart accumalator to a fellow racer,I'm probally going to regret that soon I would put the three quart in and have it as a reservior in case of a oil pump or oil pump drive failure
