what size Accusump?
#509389
10/27/09 09:57 PM
10/27/09 09:57 PM
Posts: 2,432 NorCal
RylisPro
NorCal
1 or 2 quart Accusump? I shouldn't need a 3 quart... or should I? just need it for pre-oiling a big block with drysump thanks
Re: what size Accusump?
[Re: Ben Holt]
#509393
10/28/09 12:54 AM
10/28/09 12:54 AM
Posts: 2,432 NorCal
RylisPro
NorCal
If you're concerned with priming it, just take the belt off and spin it with an electric drill prior to initial startup
two problems with that: 1. my dry sump runs off the oil pump drive, so no belt 2. I am lazy
I agree, I don't really need it & don't want the extra weight just a nice to have option was just wondering if 1 quart of oil was enough to pre-oil a big block
thanks
[Re: go green]
#509394
10/28/09 12:57 AM
10/28/09 12:57 AM
Posts: 11,683 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
At least 2, 3 if you have space. I know on the Morosos, you won't get 3qt in the 3qt Accusump. More like 2 1/2 depending on how much air pressure charge you use and how much engine oil pressure is. I like them, put the electric valve on it if it doesn't come with one.
Post deleted by Defbob
[Re: CMcAllister]
#509395
10/28/09 02:15 AM
10/28/09 02:15 AM
#509396
10/28/09 02:49 AM
10/28/09 02:49 AM
I put a 3qt. on mine with an electric switch..It works great
[Re: RylisPro]
#509397
10/28/09 05:38 AM
10/28/09 05:38 AM
#509399
10/28/09 10:36 PM
10/28/09 10:36 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Have you decided on a oil heater yet ?
nope haven't thought that far yet... can you recommend one?
warm oil, cold coolant right? how are you achieveing that with the Evans stuff?
I'll let you know about the fiberglass stuff too thanks Fred,
