Re: LA or Magnum
[Re: chache876]
#509286
10/27/09 11:27 PM
10/27/09 11:27 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
just so you know, LA style valve covers fit on magnum engines so its not a 'for sure' sign.
Yep, and Magnum heads fit on LA blocks, so that ain't a 'for sure' sign either.
Re: LA or Magnum
[Re: Reggie]
#509287
10/28/09 12:06 AM
10/28/09 12:06 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
The easiest way to tell if the block is LA or magnum is to look on the back of the block right below the pass. side head and see if there is a mounting spot for a crank sensor. The crank sensor bolts directly to the block via two bolts going straight up and down to the crank.
Re: LA or Magnum
[Re: 70AARcuda]
#509289
10/28/09 08:20 AM
10/28/09 08:20 AM
Posts: 2,826 NY usa
540challenger
NY usa
i got two 1989 360s that are LA engines that have the mount for the crank sensor on them...so.....
i would go with the valve covers and look at the intake bolts...vertical for magnums
Magnums also have different motor mount provisons
They have the LA "Ear" type Plus the newer style which bolt directly into the block.
The LA only has the ear type
Re: LA or Magnum
[Re: coronetkid]
#509292
10/30/09 12:59 AM
10/30/09 12:59 AM
HotRodDave
Kalispell Mt.
I just double checked my 91 360 and it does not have the magnum mount holes or the crank sensor mount.
Re: LA or Magnum
[Re: HotRodDave]
#509293
10/30/09 08:04 AM
10/30/09 08:04 AM
Posts: 15,487 Florida
scratchnfotraction
mags are 92-93 91 is a pre-mag roller cam block,it would not have the mag mounts,IIRC and my 1990 per-mag oiled the old LA style thru the block,heads,shafts,rockers AND had oil thru lifters with hollow push rods though.. geared up for mag heads in 92
