Truck 440 cam selection help... #508774
10/27/09 01:40 PM
10/27/09 01:40 PM
Mesa, AZ
P
Pat_Whalen Offline OP
super gas
super gas
P
Mesa, AZ
Looking into the summit cam/lifters kit.
The engine in question is a 1978 440, standard bore, stock pistons, untouched 452 heads, cast iron manifolds. Engine is going in an 80 ramcharger, 35" tires, unsure of axle ratios at this point, 727/205 combination.
I would like a fairly low power band to get this beast moving, I'd like it to "sound" like it's got a hotter cam in it, and I'd like to not sacrifice drivability or vacuum.
I saw summit lists two camshaft kits:
The SUM-K6401 which is 282/292, .465"/.468"
The SUM-K6400 which is 272/282, .442"/.465"
As I understand it, the lower duration brings the power curve down a bit in the RPM range, but obviously at the sacrifice of lift. I would also prefer not to have to change to different springs, unless not doing so would leave something on the table.
The truck will be daily driven, mostly road but the occassional weekend jaunt through the rocks.
Appreciate the help!
Cheers
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508775
10/27/09 01:46 PM
10/27/09 01:46 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
The smaller summit cam with stock gears. The rule of the game says to match springs, cam, compression, intake,and carb for the engines' demand .
Use it with a Weiand action + (super low rise ribbed) and a 750 edelbrock AFB/or AVS carb. #2 streeet choice is TQ.
Can wind out to 4500-5000rpms, but you will not have "drag racer" top end.
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508776
10/27/09 01:46 PM
10/27/09 01:46 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you're looking for peak bottom end power and mileage, IMO you're best off sticking with a stock cam. The torq/rv grinds that are out there are so similar in spec to stock, I don't think it's worth the $$ to change. Put a set of straight dual exhaust on it, no x or h pipe, decent mufflers and even a stock 440 will sound decent.
Re: Truck 440 cam selection help... [Re: mark7171] #508777
10/27/09 03:14 PM
10/27/09 03:14 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
Would an Edelbrock Performer intake work well with this combination?
Re: Truck 440 cam selection help... [Re: DaytonaTurbo] #508778
10/27/09 03:25 PM
10/27/09 03:25 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
Is there anything out there that is budget-based (~100 bucks) that would come with lifters that is close to stock. I'm not aware of the stock specifications. I'd love to not have to spend money in the arena but due to a rusted cam and lifters, I'll need to replace them. And since I'm replacing them, I figured I'd find out what's the best option.
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508779
10/27/09 03:41 PM
10/27/09 03:41 PM
scratchnfotraction Offline
for low budget,you cant beat the smaller summet cam and lifter package
I am going with a hughes whiplash for mine
its for stock low comp engines,idles like a funny car and smoothes out around 2000 rpms,runs about 165$ for cam,IIRC
should work fine in the truck I am building
Re: Truck 440 cam selection help... [Re: scratchnfotraction] #508780
10/27/09 03:50 PM
10/27/09 03:50 PM
Indiana, United Staes, Vevay
LikarockCrusher Offline
Hey, Whats the specs. on that cam do you have them?
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508781
10/27/09 03:57 PM
10/27/09 03:57 PM
Give me a little while I'll give you some Hp and Tq specs. with RPM ratings.
Re: Truck 440 cam selection help... [Re: LikarockCrusher] #508782
10/27/09 03:58 PM
10/27/09 03:58 PM
look them up on hughes website
whiplash or muscle car cams,IIRC
early intake closing to build cyl pressure,so its not a dog...good street cruzer cam
gonna have them grind up a roller for the SB stepside I drive daily
running the 60710 voodoo cam in the sb right now
the 360 got the lunati bracket master II in it 292/292
want that sound but not the dog out the hole part the 292 has
Re: Truck 440 cam selection help... [Re: scratchnfotraction] #508783
10/27/09 04:04 PM
10/27/09 04:04 PM
All right thought you might had them on hand.
Re: Truck 440 cam selection help... [Re: LikarockCrusher] #508784
10/27/09 04:06 PM
10/27/09 04:06 PM
no didnt right it down sorry..
just have read/heard good things on the whiplash and I want to try one
if its as there sales pitch goes..idles like a funny car smoothes out around 2000 rpms and good for red light to red light performance
its right up my ally for a poser cam in the 440 truck
Re: Truck 440 cam selection help... [Re: scratchnfotraction] #508785
10/27/09 05:36 PM
10/27/09 05:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The K6400 would be your best bet of the two!
Re: Truck 440 cam selection help... [Re: Dodgem] #508786
10/27/09 05:49 PM
10/27/09 05:49 PM
Manitoba, Canada
Manitoba, Canada
If your stock cam is trash, then the summit k6400 kit is your best bet. Stock lo-po 440 cam is said to be about 210 @050 and .430 lift.
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508787
10/27/09 06:16 PM
10/27/09 06:16 PM
The whiplash I believe is to much for your combo the other two you listed with your engine look good. Looks like the 6400 will be around 325 hp@4000 and 502 tq@2500 now this isn't perfect numbers but gives a good ideal. Good torque.
Re: Truck 440 cam selection help... [Re: LikarockCrusher] #508788
10/27/09 06:32 PM
10/27/09 06:32 PM
how is the whiplash too much??
its for a stock lopo engine with stock verter and low comp
building cyl pressure is good on a lopo/low comp engine..no?
Re: Truck 440 cam selection help... [Re: scratchnfotraction] #508789
10/27/09 06:56 PM
10/27/09 06:56 PM
Manitoba, Canada
Manitoba, Canada
Depends on what you're using it for. Looking at the specs it's got a lot of duration but a fairly early intake valve closing angle to help build cylinder pressure. However it's also got a narrow LSA which is going to result in low vacuum and lowered throttle response and lower fuel mileage. If that's what you want then go for it. Should sound awesome at idle though. It sounds like a good cam for a low CR street machine, would not be my first choice for an off roader cam though.
Re: Truck 440 cam selection help... [Re: DaytonaTurbo] #508790
10/27/09 07:15 PM
10/27/09 07:15 PM
I can see your point on that
may not be a good one for a 4x4 and low end
I am going with an 85 short bed 2 wheel drive for a street bruzer
a poser cam for showboating on the streets
Re: Truck 440 cam selection help... [Re: DaytonaTurbo] #508791
10/27/09 07:33 PM
10/27/09 07:33 PM
He said he has stock intake,heads,and comp.
Re: Truck 440 cam selection help... [Re: LikarockCrusher] #508792
10/27/09 08:36 PM
10/27/09 08:36 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
I think there may be some confusion.
Scratchin is going with the Hughes Whiplash cam for his truck.
I will most likely be going with the recommendations of the K6400 from Summit.
I believe both of us have very different goals for our trucks
Re: Truck 440 cam selection help... [Re: Pat_Whalen] #508793
10/27/09 08:37 PM
10/27/09 08:37 PM
Mesa, AZ
P
super gas
super gas
P
Mesa, AZ
So is it safe to assume that the stock valve springs on the 452 heads will be able to handle the 6400 cam? Or do I need to look into a new set of them.
