Power steering pump on a 73 440?
#508658
10/27/09 09:26 AM
10/27/09 09:26 AM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
I have a 73 440 in my 64 polara. The car is equiped with power steering but when I bought the motor it didn't have the pump or brackets needed for the pump. I riggged up a unit from a 60's truck but it has given me problems since day one. It has developed a major leak and I want to put something closer to original on it.Can any one show me pictures of what I need or supply part numbers? Thanks.
This would be so much easier if I knew what I was doing...
Re: Power steering pump on a 73 440?
[Re: Commando1]
#508662
10/28/09 08:55 AM
10/28/09 08:55 AM
Polarabill
N.E.Ohio
Thanks, those pics will give me an idea on what to look for.
[Re: Polarabill]
#508663
10/28/09 11:42 AM
10/28/09 11:42 AM
Posts: 203 florida
74fldart
florida
here is a higher mount set up, go to 440source.com for brackets.
[Re: 74fldart]
#508664
10/30/09 11:03 PM
10/30/09 11:03 PM
Posts: 6,140 Valencia, España
NachoRT74
Valencia, España
Those are federal pumnps... saginaw brackets are diff but fits on same places at block/water pump housing.
The higher mounting kind is for cars with water pump inlet on driver side ( pre 72 )
