Re: Nitrous cams??? [Re: challenger451ci] #508604
10/29/09 12:33 AM
10/29/09 12:33 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thanks for the input! Can anyone recommend a cam grinder that would help steer my combination in the right direction?
You havent stated your combination???? So What is it??
If its a mild nitrous combo, a regular NA 108/110 LS cam will work fine.
But Comp cams for one, can grind you anything you want. mike
Re: Nitrous cams??? [Re: Sport440] #508605
10/29/09 12:39 AM
10/29/09 12:39 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Tim@Bullet racing cams. 662-893-8022
Re: Nitrous cams??? [Re: Sport440] #508606
10/29/09 05:07 PM
10/29/09 05:07 PM
NY
challenger451ci Offline OP
NY
451ci, low deck, Indy SR's, 10.9:1,Victor intake w/ NOS fogger, 1050 dominator on E85, 4:10, 28" tire, 3500lbs.
Looking at changing a few things over the winter (more nitrous) and cam is one of them...solid lifter.
0.648"int/0.640"exh, 263@0.050/272@0.050, 110LSA, in at 105 Int CL
Re: Nitrous cams??? [Re: challenger451ci] #508607
10/29/09 05:21 PM
10/29/09 05:21 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think some exhaust flow #s would help a lot on pickin a nos cam , if you dont have any flow info , head type and valve size and if any port work has been done , then some basic exhaust system info , headers, open or muffs ect...
