Re: Nitrous cams???
[Re: challenger451ci]
#508604
10/29/09 12:33 AM
10/29/09 12:33 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Thanks for the input! Can anyone recommend a cam grinder that would help steer my combination in the right direction?
You havent stated your combination???? So What is it??
If its a mild nitrous combo, a regular NA 108/110 LS cam will work fine.
But Comp cams for one, can grind you anything you want. mike
Re: Nitrous cams???
[Re: Sport440]
#508606
10/29/09 05:07 PM
10/29/09 05:07 PM
Posts: 292 NY
challenger451ci
NY
451ci, low deck, Indy SR's, 10.9:1,Victor intake w/ NOS fogger, 1050 dominator on E85, 4:10, 28" tire, 3500lbs. Looking at changing a few things over the winter (more nitrous) and cam is one of them...solid lifter. 0.648"int/0.640"exh, 263@0.050/272@0.050, 110LSA, in at 105 Int CL
