Nitrous cams??? #508584
10/26/09 10:12 PM
10/26/09 10:12 PM
NY
challenger451ci Offline OP
NY
I'm looking for recommendations on where to go to get a good nitrous cam. Anyone have suggestions?
Thanks!
Re: Nitrous cams??? [Re: challenger451ci] #508585
10/26/09 11:02 PM
10/26/09 11:02 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
if running 250 hp and under just run a aspirated cam
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Nitrous cams??? [Re: Ian] #508586
10/27/09 12:00 AM
10/27/09 12:00 AM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
DEAD WRONG!!!!!!!!!!!!!!!!
Re: Nitrous cams??? [Re: 8secDart] #508587
10/27/09 07:33 AM
10/27/09 07:33 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Why don't you explain?
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Nitrous cams??? [Re: bigsbigelow] #508588
10/27/09 11:08 AM
10/27/09 11:08 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i ran a 360 with a mopar557 singe patten cam on a 106 lc a total aspirated cam and with a 175 shot made 155 extra at the tyres picked up 12 mph and 1.2 seconds ,google nitrous cam and you will see that i am not far out
Re: Nitrous cams??? [Re: bigsbigelow] #508589
10/27/09 01:02 PM
10/27/09 01:02 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
It really depends on what you expect from it. If you are in a heads up class where you are limited to 1 250 HP plate there may be better choices but if you just want to go fast the N/A cam will certainly do the job. No one that runs heads up programs will give you this information. You need to contact a good cam grinder. They will be happy to sell it to you.
Re: Nitrous cams??? [Re: Ian] #508590
10/27/09 01:12 PM
10/27/09 01:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
I know some very susseful NOS racers that ran a bunch more than a single 250 HP plate system, they spent thousands of dollars expermenting with all types of different combinations and they ended up using a N/A SS style cam after trying all of the NOS grind cams There is a point where the C.I. and the intended RPM range will come into play, especially on the lobe seperation angles
Re: Nitrous cams??? [Re: Cab_Burge] #508591
10/27/09 07:27 PM
10/27/09 07:27 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A lot of N/A cams, especially for Mopars, seem to have very short LSA numbers. With very much of a nitrous shot, all that overlap, just sucks the nitrous charge straight out the exhaust and you don't get all the benefit. Will it work, obviously it will. Will it be optimum for nitrous, no it won't. Given the near exact specs, a longer LSA cam will be better for nitrous than a short LSA cam everytime.
Monte
Re: Nitrous cams??? [Re: challenger451ci] #508592
10/27/09 07:32 PM
10/27/09 07:32 PM
organ
maximum entropy Offline
organ
you're going to need AT LEAST a 3/4 cam. and stage three rods, or she may blow.
Re: Nitrous cams??? [Re: Monte_Smith] #508593
10/27/09 07:37 PM
10/27/09 07:37 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I agree with Monte here extra lobe seperation is your freind when running nitrous.
Some run more exhaust duration to. I think you can be conservative here on some of the heads that have good flowing exhaust characteristics. My CFE W8 heads on the small block nitrous engine I ran could not get enough exhaust lobe duration. The heads were designed purely for NA combinations and only have a 1.55" exhaust valve. I simply had the cam grinder put all the lobe seperation and exhaust duration physically possible in using that core. We just went back and fourth on LSA and Duration trying to find the sweet spot. If I told the specs you would swear it was an IHRA pro stock cam with a huge LSA.
Leon
Re: Nitrous cams??? [Re: Leon441] #508594
10/27/09 08:41 PM
10/27/09 08:41 PM
NY
NY
Thanks for the input! Can anyone recommend a cam grinder that would help steer my combination in the right direction?
Re: Nitrous cams??? [Re: 8secDart] #508595
10/27/09 09:08 PM
10/27/09 09:08 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
NICE INFO!!!!!!!!!!!!!! Get over yourself. You ran a 8, that dont impress me much song
Nitrous cams should have wider LS angles to help prevent the nitrous from being sucked out the exhaust at overlap. The overlap Pulse can/is Very strong in a well set up NA motor.
A nitrous motor doesnt need or want as strong a pulse IMO, A wider LS helps with that.
But for mild nitrous combos NA cams can work just fine as most are around a 108 to 110 LS anyways. miker
Re: Nitrous cams??? [Re: Sport440] #508596
10/27/09 10:07 PM
10/27/09 10:07 PM
8secDart Offline
8secDart  Offline
Go back and play under your rock dick head.Lenny
Re: Nitrous cams??? [Re: 8secDart] #508597
10/27/09 10:14 PM
10/27/09 10:14 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Again NICE INFO!!!!! Are you here to help or Stroke your ego.?EGO
If you dont have anything good to add to a thread then, just dont respond.
Lenny,Learn to be Nice!!!!! miker
Re: Nitrous cams??? [Re: Sport440] #508598
10/27/09 10:26 PM
10/27/09 10:26 PM
8secDart Offline
8secDart  Offline
I did add to the post.Someone posted something that I tought was bad info.I like most people in this business aren't going to give cam specs out.Now how is that about my ego.I spent years and a hell of a lot of money to get a good combo.My customers get that info,not people on the net looking for a give me.Have a nice day!Is that nice enough.Lenny
Re: Nitrous cams??? [Re: 8secDart] #508599
10/27/09 10:57 PM
10/27/09 10:57 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I understand what you are saying but since you feel that way you may be better off saying nothing than being purely negative.
Re: Nitrous cams??? [Re: 8secDart] #508600
10/27/09 11:04 PM
10/27/09 11:04 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You ADDED To the post??????!! You stated :
DEAD WRONG!!!!!!! Thanks!! That helps alot
Now THATS!!!!!,About your EGO!!
If you really wanted to help, You would just state that Nitrous combos like wider lobe seps.
Its NO big secret
And in case YOU dont know mild nitrous combos can work fine with NA cams around a 108 to 110 lobe sep.
And with your comment of Have a nice day, Is That nice enough,
No , As it wasnt sincere!! But you know what, you can work on that. miker
Re: Nitrous cams??? [Re: Sport440] #508601
10/28/09 01:39 AM
10/28/09 01:39 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
http://www.stangtv.com/forum/nitrous-cam-101-dyno-testing-four-5724.html#
most guys wont the best asperated car on the street and nitrous at the strip i have ran nitous for 15 years and design my cams for nos if you pm me all the eng specs and usage i will spec you one.
Re: Nitrous cams??? [Re: Ian] #508602
10/28/09 08:47 AM
10/28/09 08:47 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Good info
Re: Nitrous cams??? [Re: emarine01] #508603
10/29/09 12:08 AM
10/29/09 12:08 AM
Waterford,NY
V
Vintage Offline
Vintage  Offline
V
Waterford,NY
I think the post is asking for suggestions on a Nitrous cam grinder.Do any of you guys have any favorite cam grinders that are familiar with mopars and NO2.Or if any of you either sell or grind or spec your own NO2 specific cams now would be a good time to speak up.I think he would pay for a camshaft.
