Vacuum Pump install without a motorplate?
#508383
10/26/09 08:16 PM
10/26/09 08:16 PM
has anyone ever ran and installed a vacuum pump without a motorplate? does anyone make a bracket to mount to the head, iwant to install one on my 65 plymouth. i dont run a motorplate,just motormounts?
Re: Vacuum Pump install without a motorplate?
#508384
10/26/09 10:52 PM
10/26/09 10:52 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Just make a plate that sits between the block and water pump off to the one side and mount it on there. Actually its easy.
BB, TT5,Procharged 3300lb Street Car 4.79/154
#508385
10/26/09 10:59 PM
10/26/09 10:59 PM
ARC should be able to fix you right up. lots of guys do it without a motor plate.
#508386
10/27/09 07:01 AM
10/27/09 07:01 AM
DRAM thanks so much for your informative answer, i'll get right on that!
#508387
10/27/09 07:02 AM
10/27/09 07:02 AM
anyone have a picture of how it can be done?
#508388
10/27/09 10:15 AM
10/27/09 10:15 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
mounted to the head, not the motor plate, i had to make the braket
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: HemiDart68]
#508390
10/27/09 05:44 PM
10/27/09 05:44 PM
one more
Matt, thanks very much for the picture, im rnning same low mount alternator and bracket , so that setup is identical to what i'm looking for, any chance you have a picture of that bracket? thanks again. Chris
#508391
10/27/09 07:25 PM
10/27/09 07:25 PM
HemiDart68
North of Detroit
No thats all i have, and the car is in a far away land. All we did was make a quick template out of cardboard to fit the pump. There is bolt through the bracket that you cant see that the plate pivots on, then just picked up the other bolt hole on the head. Then just kind of cut it on the band saw. Had to put it on a bridgeport to cut the radius so you could use the plate as a tensioner.
[Re: HemiDart68]
#508392
10/27/09 07:53 PM
10/27/09 07:53 PM
i'm liking that alot. is the bracket you made, the red billet aluminum piece? i understand now what you did,looks great.
#508394
10/27/09 08:36 PM
10/27/09 08:36 PM
HemiDart68
North of Detroit
Yes sir, made the red piece behind the vacum pump.
