Re: Holley Carb Experts........
[Re: BIGS]
#507922
10/26/09 02:45 PM
10/26/09 02:45 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Well I'll give it a shot.... have to pick up a 12-24 kit @ machine shop in State College & try it tomorrow. It's not an area I really want to "half A**" something, as if that screw comes out, bye bye motor...... It's just assinine to me someone would mass produce a part that does'nt have a readily available thread repair kit for it.... Why would'nt Holley use a 12-24 screw instead of the oddball 12-28? It's just another example of engineers out-thinking themselves & not using common sense. But thanks for the reply Jesse, I'll give it a shot as it sounds like you've repaired them like this before. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RyanJ]
#507923
10/26/09 02:55 PM
10/26/09 02:55 PM
Posts: 5,080 organ
maximum entropy
organ
DON'T JUNK IT! i found a tool supply house in florida that carries the correct heli-coil. i'll get the name when i get home. i ordered a set for my carb, and it worked out slicker than snot!
[Re: BradH]
#507925
10/26/09 04:10 PM
10/26/09 04:10 PM
RyanJ
moparts member
moparts member
State College, PA
IIRC (and I'm old enough now that I may NOT ), BLP offers a repair kit for that.
I just checked the BLP catalog, they do offer a screw repair kit, it's not a heli-coil though..... It's a reamer & sleeve kit... not sure exactly how it works but I'm going to call & price it & possibly order one right now......
[Re: hp340nos]
#507928
10/26/09 07:45 PM
10/26/09 07:45 PM
Posts: 2,521 Richmond Va, KeislerTKO 60...
VanishPt
here you go. i have one of these. I also have a 12-24 setup that AED put in one of my carbs. the 12/24 does work.
[url=http://www.allfasteners.com/Recoil-Thread-Repair-Kit-34620-12-28-4010pcs41-403462041_p_2308.htm]
do a parts search for 34620
[Re: RyanJ]
#507930
10/26/09 11:38 PM
10/26/09 11:38 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
$28 for the BLP kit, he said they sell a ton of them & were almost out. So it's on it's way, I'll post my results on this thread when it gets fixed.
I found out about those ? last year. It worked quite well and I now keep a few in stock.
I still upgraded the main body anyway...
I miss having high idle and choke!
[Re: 70Cuda383]
#507933
10/27/09 12:39 AM
10/27/09 12:39 AM
Jeremiah
Rogue River, OR
Na, it's called foreplay!
That is a good one, I never have heard it before. For the increase in how the car ran it was well worth a little footsie in the garage before gettin it on! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Jeremiah]
#507934
10/27/09 07:48 AM
10/27/09 07:48 AM
Posts: 15,493 the boonies
aarcuda
the boonies
i gotta remember that one.
anyways, real race cars dont have chokes
[Re: RyanJ]
#507935
10/27/09 09:57 AM
10/27/09 09:57 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Ryan, I just installed one of the BLP repair kits in a Ford 3x2 center carb. It's definately a measure twice - cut once deal. After you ream the hole to the right depth, sneaking up on it so you don't ruin the taper at the bottom, make sure you measure the depth and trim the bottom of the insert to length before you Loctite it in. The insert we had was long, and the stackup with the tapered pin and the squirter screw is tight . You'll see what I mean when you get the kit. ![](/ubbthreads/images/graemlins/beer.gif)
Free advice and worth every penny... Factory trained Slinky rewinder.........
