4-speed experts, need help identifying these pedals #507764
10/26/09 11:34 AM
10/26/09 11:34 AM
near Port Huron, MI
Paul Offline OP
Paul  Offline OP
near Port Huron, MI
Friend just picked these up, but I suspect they aren't the correct peddles for his car.
Can anyone ID the application?
Thanks!!
Re: 4-speed experts, need help identifying these pedals [Re: Paul] #507765
10/26/09 11:35 AM
10/26/09 11:35 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
A-BODY
Re: 4-speed experts, need help identifying these pedals [Re: TONY_DAGOSTINO] #507766
10/26/09 11:43 AM
10/26/09 11:43 AM
near Port Huron, MI
Paul Offline OP
Paul  Offline OP
near Port Huron, MI
That was fast, thanks Tony!
Will they fit any year a-body?
Re: 4-speed experts, need help identifying these pedals [Re: Paul] #507767
10/26/09 12:49 PM
10/26/09 12:49 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Yes A body pedals. Fit 67-76 model years.
If they have the clutch switch, they are 70+. From the shape of the pedal arms, I'm going to guess they are from a 67-72 car.
Re: 4-speed experts, need help identifying these pedals [Re: RobX4406] #507768
10/26/09 05:57 PM
10/26/09 05:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The one on the left is the clutch, and the one on the right is the brake.
Sorry, I've always wanted to do that...:)
Re: 4-speed experts, need help identifying these pedals [Re: Paul] #507769
10/26/09 09:43 PM
10/26/09 09:43 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I have a set like that out of a '70 340 swinger, I also have a set from a '68 that look completely different but all the mounting points are the same.
Those pedals use metal bearings on the clutch pedal and the '67-69 uses plastic bushings.
