Transmission leak, need help please #507454
10/25/09 09:49 PM
10/25/09 09:49 PM
Utah
dragnduster Offline OP
Utah
I just got my street car up an running a couple weeks ago an took it to the track to test and tune the combo and found that I have a tranny leak back around the tranny mount when I make a pass, it leaks out on the exhaust H pipe leaving alot of smoke behind me. The tranny never leaked before and the only thing I did to it was drop the tranny mount and lower the tail shaft to slide a tranny blanket into place. Is there anything in that area that could be leaking? I've looked it over good and ruled out anything forward of the speedometer gear and it is not coming from the seal at the end of the tail shaft. One other thing, when I had it apart I misplaced the bolts from the mount to the housing and had to get new ones that ended up alittle longer than the others, is it possible that they pushed thru into the area of the housing where oil is and the leak is coming from around the mount bolts? Thanks for the help. Dave
Re: Transmission leak, need help please [Re: dragnduster] #507455
10/25/09 10:28 PM
10/25/09 10:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its possible the new bolts went through... they would.
need to be a fair bit longer.... but anything is possible.
Does it look like its coming from the mount area.
Put it up on stands and run it in gear and watch it.
Hope you find it... thats a strange one.
Do you have the vent in the rear... check for the fluid
being over filled(check it in neutral)
Re: Transmission leak, need help please [Re: MR_P_BODY] #507456
10/25/09 10:44 PM
10/25/09 10:44 PM
Utah
Utah
Thanks Mr P Body, I still have the stock vent in the bell housing area, I checked the tranny level at the track with it hot after a run and it was just under full. Took the car out for a drive today and noticed smoke when I jumped on it, stopped and looked and it was dripping down the back side of the mount. When the car is idling or shut off it doesn't seem to leak, but when I am in the throttle it leaks pretty good. Checked the tranny level when I got back home today and it was just at the add mark now.
Re: Transmission leak, need help please [Re: dragnduster] #507457
10/25/09 10:57 PM
10/25/09 10:57 PM
Hemiroid Offline
Hemiroid  Offline
Check the rear trans line fitting. It may have gotten cracked from moving the trans around. It seals when static, but when the trans rolls over with a load it opens up and leaks. Something to look at anyways.
Re: Transmission leak, need help please [Re: Hemiroid] #507458
10/25/09 11:04 PM
10/25/09 11:04 PM
Utah
Utah
Thanks Hemiroid, I was thinking the same thing and checked that. I undid the tranny blanket and everything in that area is dry. I wish I could get it to leak when the car is idling and I can get under it to see the leak, but it only seems to do it when I'm on the throttle hard and running it thru the gears.
Re: Transmission leak, need help please [Re: dragnduster] #507459
10/25/09 11:59 PM
10/25/09 11:59 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Get some to help you, put it on horses and run threw the gears, while you under there looking, good luck
Re: Transmission leak, need help please [Re: B1KILLER] #507460
10/26/09 07:45 AM
10/26/09 07:45 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Under the transmission mount there are two philips head screws that hold a narrow plate that is used to cover the access slot for the rear tail bearing retaining snap ring. Check and see if this plate is tight.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Transmission leak, need help please [Re: turbobitt] #507461
10/26/09 07:59 AM
10/26/09 07:59 AM
in the back of the trans. infront of the tailshaft above the trans, pan there is a small little 1/4 plug towards the passenger side,mine was leaking from there and couldnt tell where it was coming from. worth checking out.
Re: Transmission leak, need help please #507462
10/26/09 09:27 AM
10/26/09 09:27 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
cracked tail shaft???? I had one...didn't leak until I was "in it" hard as heck to see too because it's a hair line crack.
Coming soon!!!!
Re: Transmission leak, need help please [Re: turbobitt] #507463
10/26/09 06:30 PM
10/26/09 06:30 PM
Utah
Utah
Thanks Turbobitt, I just checked that and it doesn't look like the problem. My tranny has that narrow plate on the side of the tail shaft housing instead of under the tranny mount. It was dry right there, but thanks for the idea.
Re: Transmission leak, need help please #507464
10/26/09 06:37 PM
10/26/09 06:37 PM
Utah
Utah
Thanks for the help Superstockracer, I checked that plug you are talking about and that area was dry also but I apprecciate the idea. The oil seems concentrated at the mount area so I'm starting to think I may have cracked the tail shaft housing when I had to use a little longer bolt . I'll have to drop the exhaust and tranny mount next and see.
Re: Transmission leak, need help please [Re: Mr.Yuck] #507465
10/26/09 06:40 PM
10/26/09 06:40 PM
Utah
Utah
Was yours cracked right at the mount or was it some place else on the tail shaft housing? Thanks for the help.
