Re: Transmission leak, need help please
[Re: dragnduster]
#507455
10/25/09 10:28 PM
10/25/09 10:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its possible the new bolts went through... they would. need to be a fair bit longer.... but anything is possible. Does it look like its coming from the mount area. Put it up on stands and run it in gear and watch it. Hope you find it... thats a strange one. Do you have the vent in the rear... check for the fluid being over filled(check it in neutral)
[Re: dragnduster]
#507459
10/25/09 11:59 PM
10/25/09 11:59 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Get some to help you, put it on horses and run threw the gears, while you under there looking, good luck
[Re: B1KILLER]
#507460
10/26/09 07:45 AM
10/26/09 07:45 AM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
Under the transmission mount there are two philips head screws that hold a narrow plate that is used to cover the access slot for the rear tail bearing retaining snap ring. Check and see if this plate is tight.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#507461
10/26/09 07:59 AM
10/26/09 07:59 AM
in the back of the trans. infront of the tailshaft above the trans, pan there is a small little 1/4 plug towards the passenger side,mine was leaking from there and couldnt tell where it was coming from. worth checking out.
[Re: turbobitt]
#507463
10/26/09 06:30 PM
10/26/09 06:30 PM
Posts: 316 Utah
dragnduster
Utah
Thanks Turbobitt, I just checked that and it doesn't look like the problem. My tranny has that narrow plate on the side of the tail shaft housing instead of under the tranny mount. It was dry right there, but thanks for the idea.
#507464
10/26/09 06:37 PM
10/26/09 06:37 PM
Posts: 316 Utah
dragnduster
Utah
Thanks for the help Superstockracer, I checked that plug you are talking about and that area was dry also but I apprecciate the idea. The oil seems concentrated at the mount area so I'm starting to think I may have cracked the tail shaft housing when I had to use a little longer bolt . I'll have to drop the exhaust and tranny mount next and see.
[Re: Mr.Yuck]
#507465
10/26/09 06:40 PM
10/26/09 06:40 PM
Posts: 316 Utah
dragnduster
Utah
cracked tail shaft???? I had one...didn't leak until I was "in it" hard as heck to see too because it's a hair line crack.
Was yours cracked right at the mount or was it some place else on the tail shaft housing? Thanks for the help.
