Re: Max C.I. with aluminum rods in a stock block
[Re: 506RR]
#507267
10/26/09 06:25 PM
10/26/09 06:25 PM
Posts: 672 Keysville, VA
drag440
mopar addict
mopar addict
Keysville, VA
With aluminum rods, you could make a 4.25 fit. Which would be ~505 CI, depending on overbore, not 528. A 4.375 stroke would be about 528 CI.
I have never seen a 4.5 stroke with aluminum rods in a stock block, but as mentioned above, it sounds like it can be done.
Thanks for the info. The 4.375 crank was the one that I was woundering if it would fit. I didn't think 4.500 would work at all. I was also worried about the rods hitting the cam.
[Re: drag440]
#507268
10/26/09 07:08 PM
10/26/09 07:08 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I had a set of BME aluminum rods made with 2.100 journals, 7.050 long for an offset ground stock crank. I would bet you could easily go 4.5+ stroke with those, being so small. I wouldn't try it on anything but the absolute best crank material though!
