Re: Clearance Problem with Viscous Fan-What's Wrong?
[Re: tact1]
#507137
10/26/09 12:31 AM
10/26/09 12:31 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
They dont fit, and neither does a parts store replacement. They will probably fit the E body style cars.. There is a replacement clutch that does fit, it is just not listed for 68-70 Mopars....
[Re: radiatorman]
#507139
10/26/09 09:54 AM
10/26/09 09:54 AM
Posts: 163 Beautiful Downtown Bahama, NC
tact1
Thanks, with a part # I can probably fix it. I had one on my first Super Bee that I bought in '69 so I know that at one time they made the correct ones. Why don't they make them now?
"Four out of three people have a problem with fractions"
[Re: basik]
#507142
10/26/09 11:03 PM
10/26/09 11:03 PM
Posts: 17,861 albany ny
05dakota
albany ny
[Re: radiatorman]
#507143
10/27/09 08:51 PM
10/27/09 08:51 PM
Posts: 1,522 Orleans, Ontario
moparcanuk
Orleans, Ontario
Mopar replacement fan clutch = 3.65" tall Hayden part #2765 fan clutch = 2.58" tall The only downside is that the hub holes are slotted.
Good luck, Bob
Fit on my GTX perfectly
[Re: moparcanuk]
#507145
10/27/09 09:36 PM
10/27/09 09:36 PM
tact1
I had a thought yesterday about this problem, and that led me to my "spare parts pile" near my garage, the one my wife says I gotta clean up. I found 2 fans and viscous drive clutches that I had removed from a couple of engines that I bought last year. On one of them from a 440 the drive was identical to the Mopar replacement. It was also the same length. I found another that came off of a '72 400, and it was shorter by 3/4" and had different markings. It must be a Hayden, because as Radiatorman reported, the holes were slotted. It worked fine, fit is just right. Soon as I clean it up a little it will be ready to go. Only difference I saw was the bolt holes for the fan weren't as deep as the Mopar fan clutch. Oh yeah, I couldn't wait to tell the Warden that having that pile of junk saved me some money. If I could find a pair of earrings out there I will be good for another year.
[Re: tact1]
#507146
10/27/09 10:44 PM
10/27/09 10:44 PM
Posts: 5,445 So Cal
Sinitro
So Cal
The Hayden clutch fan works fine.. Our solution was to shop for a TRW FC28, this was a short height (2 3/4") Mopar replacement part. Also it had the 4 holes rather than the universal slots. Check out some of the swap meets thats where we found ours, still in the OE box... Just my $0.015...
[Re: Sinitro]
#507147
10/27/09 10:57 PM
10/27/09 10:57 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
Years ago, aboiut 1997, I got the MP kit and it fit a 69 RR no problem. That car had a 22 inch rad.
I want my fair share
[Re: radiatorman]
#507151
10/28/09 10:18 AM
10/28/09 10:18 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Although yours is shorter than mine(couldn't resist) that is the less desireable torque limiting clutch, the 2965 is a thermal. Just some info incase you didn't know.
Bob
Less desireable only unless it a 2806070,then get your wallet out.
