transmission fluid #507018
10/25/09 03:42 PM
10/25/09 03:42 PM
High Ridge MO.
MOPARCHAS Offline OP
High Ridge MO.
ok it's been asked a bunch of times
who uses what and what brand
I have been told to use ATF+3 or Dexron 2
can't find either
Re: transmission fluid [Re: MOPARCHAS] #507019
10/25/09 03:44 PM
10/25/09 03:44 PM
Kirkland, Washington
Pacnorthcuda Offline
superceded by ATF +4
Re: transmission fluid [Re: Pacnorthcuda] #507020
10/25/09 03:59 PM
10/25/09 03:59 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I use AMSOIL in mine. Type F before that.
Re: transmission fluid [Re: MOPARCHAS] #507021
10/25/09 04:48 PM
10/25/09 04:48 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
Amsoil SuperShift!!!
PRODUCT DESCRIPTION
AMSOIL Synthetic Super Shift® Racing Transmission Fluid is specifically formulated for automatic transmissions operating in high-horsepower and high-torque conditions. AMSOIL SuperShift contains top-quality additives selected specifically for racing applications. Its unmatched transmission friction performance provides high holding capacity for maximum torque transfer and brake power, reduced wear and longer clutch plate life. Super Shift virtually eliminates slippage, promotes positive clutch engagement and improves overall shift performance, helping racers improve on elapsed times.
Re: transmission fluid [Re: hemi471] #507022
10/25/09 06:02 PM
10/25/09 06:02 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Still use type F.
Re: transmission fluid [Re: MoparforLife] #507023
10/25/09 06:17 PM
10/25/09 06:17 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
was using ptc, but will be switching back to type f next season. nothing wrong with ptc, type f is easier to get.
Re: transmission fluid [Re: mopar dave] #507024
10/25/09 08:07 PM
10/25/09 08:07 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Used type F for many years with success.
Also have used dex III with success!
Re: transmission fluid [Re: cl440] #507025
10/25/09 08:26 PM
10/25/09 08:26 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
another type F user here..and as stated earlier the +3 was superseded by +4...we only use +4 in our 4speed trans(o.d)...for 3 speed's it's typeF....your results may very..as will the responses you get to this question..
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: transmission fluid [Re: MOPARCHAS] #507026
10/25/09 08:43 PM
10/25/09 08:43 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Tractor Hyd
Re: transmission fluid [Re: RussW] #507027
10/25/09 08:49 PM
10/25/09 08:49 PM
Az
Crizila Offline
Crizila  Offline
Az
Dexron 3
Fastest 300
Re: transmission fluid [Re: MOPARCHAS] #507028
10/25/09 08:52 PM
10/25/09 08:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Type F
Re: transmission fluid [Re: MR_P_BODY] #507029
10/25/09 09:23 PM
10/25/09 09:23 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I use dex/merc 3, but will get merc 5 next change, because we can't even get 3 at the ford store anymore (let alone 2)
As mentioned plus 3 is now plus 4. Dexron 2 has been gone for 10 years or so.
Re: transmission fluid [Re: dave571] #507030
10/25/09 09:39 PM
10/25/09 09:39 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
F type here, cheap is good
Re: transmission fluid [Re: wyoming] #507031
10/25/09 10:19 PM
10/25/09 10:19 PM
sg66mopar Offline
sg66mopar  Offline
2 or 3 trannies a year and 4 or 5 converter changes = Type F from BiMart. Can't bring myself to throw away 8$ per quart stuff every 30 to 40 hits. My racer buddy / tranny guru runs the same stuff.
Re: transmission fluid [Re: sg66mopar] #507032
10/25/09 10:53 PM
10/25/09 10:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
ATF+4. Ron
Re: transmission fluid [Re: 383man] #507033
10/25/09 11:00 PM
10/25/09 11:00 PM
Hemiroid Offline
Hemiroid  Offline
Type F
Re: transmission fluid [Re: Hemiroid] #507034
10/26/09 08:36 AM
10/26/09 08:36 AM
an8sec70cuda Offline
Type F. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
