Holley throttle shaft leaking #506871
10/25/09 12:15 PM
10/25/09 12:15 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I have fuel leaking around the throttle shaft of my carb. Does Holley make a repair kit?
Re: Holley throttle shaft leaking [Re: flatiron] #506872
10/25/09 12:42 PM
10/25/09 12:42 PM
If it is leaking around the throttle shafts it is leaking fuel out of the carb onto the throttle shafts, which it shouldn't do Holley does sell new throttle plate assemblys, some of the custom carb. comapny may be able to fixthe loose throttle shafts with bushing which is probally more expensive than replacing the throttle plate assembly
Re: Holley throttle shaft leaking [Re: Cab_Burge] #506873
10/25/09 12:45 PM
10/25/09 12:45 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
ProForm and Quickfuel sell replacement plates through Summit. 10% off coupon will get you one for ~135$
Re: Holley throttle shaft leaking [Re: flatiron] #506874
10/25/09 12:53 PM
10/25/09 12:53 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
When is it leaking? at idle?
