Re: Doug Herbert SB roller cams&lifters
[Re: LSP]
#506766
10/30/09 05:42 PM
10/30/09 05:42 PM
Posts: 614 ont,canada
mopartuner
ont,canada
do you have to run a herbert cam with them.? ie..smaller base circle? or any brand roller cam? also... what cam did you go with ..and did it make power?
heck while iam at it what heads did you use and what valve springs are you running? cheaspt
I used the Comp .394" CR lobes, sorry, didn't measure the base circle, just made sure the oil band in the lifter was not exposed, mild ported "J" heads, Herbert 1.500" IIRC double springs, factory 340 intake ported/plenum divider removed, JE flat tops.
Ran 10.71 @ 125 in a 3200 lb. Duster @ 3800 ft.DA last week at Fontana, Ca.
Just wanted to know the comp. ratio?I would like to try to run 10.90's with a 360,eddys,herbert cam&lifter set with 10.5/pump gas motor @3130#
410 pump gas solis flat tappet cam 10.95 so far
[Re: mopartuner]
#506767
10/30/09 10:31 PM
10/30/09 10:31 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
the biggist issue i see with herberts cams are the lack of choices...lol.. but i digess.. its got a fair bit of duration..it might bleed off too much compression.. depending on what your starting with mechanically for compression.. however...it seems there are those out there running someone elses camshaft with them. my issue/concern is if you dont use a herbert cam...you want to make sure the cam lobe base circle doesent push or seat the lifter up so high that it exposes the oil passage..and you loose oil pressure. when it comes to ordering a non herbert cam. so knowing the dimensions..the cams base circle needs to be at..might prevent a mistake.. i am very anxious to employee them..i just need to get the best data.. id hate to tear down a perfeclty good running race car..only to have to spend a ton on machine work....work and $$ i dont have time for right now... but if its a plug and play...then i am in sooner than i would hope to be...
any one with experience can chime in .. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Rapid340]
#506771
10/31/09 10:02 AM
10/31/09 10:02 AM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
R5-P7 I tried sending you a PM but it was full.
I wanted to ask what the combination was and where you shift. That motor sounds real strong for a stock intake manifold.
Sorry, PM's cleared now.
[Re: barracuda man]
#506773
10/31/09 11:11 AM
10/31/09 11:11 AM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
Im using their lifters also, no problems here either after 2 seasons and they drop right in as stated above.
Is this a solid or hydraulic roller lifter.I take it that there is no block grinding.What about oil mods to the stock block 340.
Im running a solid roller cam and lifters. I did no oiling mods at all. Just changed cams and dropped in the lifters and a bronze dist. gear. My cam has a .640 lift with a 1.5 rocker.
[Re: a408swinger]
#506774
10/31/09 01:50 PM
10/31/09 01:50 PM
mopartuner
ont,canada
I just got off the phone with the Doug herbert store and they will grind any of the small chevy grinds on the small mopar cores so that gives us alot more cams to pick from.
[Re: Ian]
#506776
10/31/09 10:17 PM
10/31/09 10:17 PM
mopartuner
ont,canada
I was thinking the 6k or the 6kr.???
