Re: HYDRAULIC LIFTERS: TO SOAK OR NOT TO SOAK
[Re: ROADRCR]
#505603
10/24/09 10:00 PM
10/24/09 10:00 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We've always put them in a clean large coffee can full of oil and let'em soak,never had any problems this way.
[Re: 70AARcuda]
#505604
10/24/09 10:05 PM
10/24/09 10:05 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
Dont pump the up or cause the lifters to be filled with oil prior to installation. This will provide a benefit in the most critical window of time (initial startup - break in) where the maximum spring pressure will not be seen by the lobe/lifter interface because the the collapsed lifter is only partialy compressing the valve spring untill the running engine gradually pumps up the lifters. But more importantly, there is a good chance you will be holding valves open and wont be able to start quickly or worse (piston valve contact, coil bind).
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Chris2581]
#505605
10/24/09 10:06 PM
10/24/09 10:06 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Most cam and lifter companies do not recommend presoaking. In fact advise against it.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: RapidRobert]
#505610
10/25/09 12:33 AM
10/25/09 12:33 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Does anyone recommend taking apart the lifters for examination purposes?
me. The assembly line people who put em together have bad days & get sloppy. I take them apart, clean/inspect & lightly oil & reassemble. Cant assume anything these days.
[Re: Crizila]
#505612
10/25/09 08:03 AM
10/25/09 08:03 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Ive always soaked mine.In 40 years never a problem.As for bending parts a solid lifter is stiffer than a hyd is.Rocky
Chrysler Firepower
