Power steering pump rebuild
#505533
10/24/09 07:24 PM
10/24/09 07:24 PM
Posts: 2,107 Third Stone from the Sun
Scotts72Rallye
A friend of mine asked where he can get his power steering pump rebuilt that's in his 68 Super Bee. I've never dealt with this issue and thought maybe one of you guys could point him in the right direction. Any recommendations? Scott
1972 Dodge Challenger Rallye UNDER CONSTRUCTION
Re: Power steering pump rebuild
[Re: Scotts72Rallye]
#505536
10/24/09 07:59 PM
10/24/09 07:59 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
do it your self. it is very easy,and you can buy the kit from advance auto, cheap.
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: 62maxwgn]
#505541
10/25/09 05:20 PM
10/25/09 05:20 PM
Posts: 27,475 So Cal
autoxcuda
So Cal
You can get any rebuilt pump from NAPA for less than $65.Other parts houses may be less and you have a warranty.Most rebuild kits only contain gaskets and seals.That is not rebuilding a pump,rebuilding consists of replacing worn or broken parts.
The full saginaw rebuild kit does come with a replacement bushing to be pressed in.
I don't think the rebuild houses put in new vanes or housings. They may pick from good used parts to replace worn out trashed pieces. Or most likely just pick from the good cores and junk the ones that are really messed up.
#505543
10/25/09 07:41 PM
10/25/09 07:41 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Bill, do you know anyone in south central PA who does full rebuilds? My friend is located in Lancaster off of route 30. Thanks. Scott
Sorry,can't help you with that one.For the price of a rebuilt,I doubt you would find someone to do it (an actual rebuild) for less.
