Re: Engine to trans shims?
[Re: goldmember]
#505425
10/24/09 07:03 PM
10/24/09 07:03 PM
Posts: 1,880 USA
Ron Silva
USA
Let me see?? Do you have a scat crank?
The thrust bearing and corresponding crank surface in my Mopar 406 crate motor got ruined because of this. I have put 3 bearings in it since then and will eventually have to replace the crankshaft.
Yes ! You need .100 to .125 "converter pull up".
It seems most of the time you will have too much, like .375, and in that case you can use washers or spacers on the converter pads to keep the snout of the converter engauged in the Transmission pump enough.
Anyhow, I did not find one source for an engine to trans spacer, but you definately need to put one in there. SO.......I ended up making my own out of .065 steel. Thats all I needed to get .125+ I purchased a "Mid plate" (motor mount)and used it as a template and used transfer punches along with pencil tracings from the back of the block to give me the final shape.
SRT DEMON ONE SEAT
[Re: MoparforLife]
#505427
10/24/09 08:19 PM
10/24/09 08:19 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Sounds like the converter isn't seated all the way into the transmission pump.
I've had this happen too... Seems like the conv is all the way in but then you spin it a bit and it slides in further.
[Re: Ron Silva]
#505429
10/25/09 09:37 AM
10/25/09 09:37 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
The converter engagement deal would be more the .100" off. Think about it. The input shaft, stator, and pump gears certainly have more engagement then .100". I highly doubt it's the crank if this combo worked before, you switched the block, and now it doesn't work... Very strange. Did you have the trans apart by any chance? I was wondering if the last clutch in the forward drum wasn't seated. That would make everything stack up by about +.100". Just trying to figure out what could cause a +.100 shift (aside from the obvious block machining issue, but let's hope that's not it )
