Re: Roll bar tubing ???
[Re: 70dusterjohn]
#504507
10/23/09 01:38 PM
10/23/09 01:38 PM
Posts: 705 Michigan
Hemiroid
Mild steel. I'm going to need a-lot of it, also different sizes other than just 1 5/8.
If it's mild steel, it would be 1 3/4", not 1 5/8".
[Re: 70dusterjohn]
#504509
10/23/09 01:52 PM
10/23/09 01:52 PM
Posts: 705 Michigan
Hemiroid
Hmmmmm Thats interesting, cause everyone that sells a 10 or 12 pt kit states that they are 1 5/8 by .134.. I know that on 8 points they a 1 3/4... And I'm pretty sure that the rule book I was looking at stated the same. Just trying to clearify...
You're correct. You never specified what you were building, my bad!!
I think the min. spec is .118 for ms, just you have to use the thicker wall to ensure it x-rays ok with no thin spots.
[Re: Hemiroid]
#504510
10/23/09 01:54 PM
10/23/09 01:54 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
Sorry bout that.. I should have been more clear.. Thanks for the responce though.
[Re: Hemiroid]
#504511
10/23/09 02:46 PM
10/23/09 02:46 PM
Quicktree
depends on what you are building. a cage you can use 15/8.
I sould have read the rest of the replys before speaking
[Re: Quicktree]
#504512
10/23/09 02:48 PM
10/23/09 02:48 PM
Posts: 705 Michigan
Hemiroid
Hey you old fart, we already figured that out! If you would have read the whole thread you would have known that
