Roll bar tubing ??? #504502
10/23/09 12:04 PM
10/23/09 12:04 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Anyone know a place in Ohio that supplies it. Any help would be great.. Thanks.
Re: Roll bar tubing ??? [Re: 70dusterjohn] #504503
10/23/09 12:06 PM
10/23/09 12:06 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
John,what do you need,we stock MS and CM
Re: Roll bar tubing ??? [Re: B G Racing] #504504
10/23/09 12:14 PM
10/23/09 12:14 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
http://www.tubulartechniques.com/ in columbus
These guys are in Strongsville:
http://www.fayind.com/
These guys are in Elyria:
http://www.aztecsteel.com/
Dillsburg Aeroplane Works
114 Sawmill Rd
Dillsburg, PA 17019
Tel: 717-432-4589
Re: Roll bar tubing ??? [Re: B G Racing] #504505
10/23/09 12:17 PM
10/23/09 12:17 PM
Deerfield, Ohio
Deerfield, Ohio
Mild steel. I'm going to need a-lot of it, also different sizes other than just 1 5/8.
Re: Roll bar tubing ??? [Re: 70dusterjohn] #504506
10/23/09 12:57 PM
10/23/09 12:57 PM
Deerfield, Ohio
Deerfield, Ohio
Re: Roll bar tubing ??? [Re: 70dusterjohn] #504507
10/23/09 01:38 PM
10/23/09 01:38 PM
Hemiroid Offline
Hemiroid  Offline
If it's mild steel, it would be 1 3/4", not 1 5/8".
Re: Roll bar tubing ??? [Re: Hemiroid] #504508
10/23/09 01:42 PM
10/23/09 01:42 PM
Deerfield, Ohio
Deerfield, Ohio
Hmmmmm Thats interesting, cause everyone that sells a 10 or 12 pt kit states that they are 1 5/8 by .134.. I know that on 8 points they a 1 3/4... And I'm pretty sure that the rule book I was looking at stated the same. Just trying to clearify...
Re: Roll bar tubing ??? [Re: 70dusterjohn] #504509
10/23/09 01:52 PM
10/23/09 01:52 PM
Hemiroid Offline
Hemiroid  Offline
You're correct. You never specified what you were building, my bad!!
I think the min. spec is .118 for ms, just you have to use the thicker wall to ensure it x-rays ok with no thin spots.
Re: Roll bar tubing ??? [Re: Hemiroid] #504510
10/23/09 01:54 PM
10/23/09 01:54 PM
Deerfield, Ohio
Deerfield, Ohio
Sorry bout that.. I should have been more clear.. Thanks for the responce though.
Re: Roll bar tubing ??? [Re: Hemiroid] #504511
10/23/09 02:46 PM
10/23/09 02:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
depends on what you are building. a cage you can use 15/8.
I sould have read the rest of the replys before speaking
Re: Roll bar tubing ??? [Re: Quicktree] #504512
10/23/09 02:48 PM
10/23/09 02:48 PM
Hemiroid Offline
Hemiroid  Offline
Hey you old fart, we already figured that out! If you would have read the whole thread you would have known that
Re: Roll bar tubing ??? [Re: Hemiroid] #504513
10/23/09 02:52 PM
10/23/09 02:52 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Or spend the extra money and use .120 wall DOM.
Jeff
69 GTX 68 Road Runner
Re: Roll bar tubing ??? [Re: B G Racing] #504514
10/26/09 02:37 PM
10/26/09 02:37 PM
Deerfield, Ohio
Deerfield, Ohio
