91 Acclaim 2.5 cuts out
#503448
10/22/09 04:49 AM
10/22/09 04:49 AM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I have a 91 Acclaim with a 2.5.
Car runs great. Once in a while it acts as if you turned the key off and back on for a split second. You can feel the motor jerk.
Does not do it all the time.
I put a new pick up in the distributor. No help.
TPS maybe? Looking for ideas??
Why does divorce cost so much?
Because it is worth it!!!!!
Re: 91 Acclaim 2.5 cuts out
[Re: mopar376d]
#503450
10/22/09 09:45 AM
10/22/09 09:45 AM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I have had an acclaim and a spirit and both would randomly shut off like that. I had to clean or replace both of there fuel pump connectors. They would get corroded and the fuel pump would shut off intermediately. On another car it was the logic controller under the dash, behind the passenger kickpanel. Good luck. I hate electrical gremlins.
[Re: IMGTX]
#503451
10/22/09 10:21 PM
10/22/09 10:21 PM
mopar376d
Russiaville, IN
Thanks for the replies.
I will check those things out. It does seem electrical.
[Re: SALEM1912]
#503454
11/05/09 06:15 AM
11/05/09 06:15 AM
mopar376d
Russiaville, IN
Update... Probably jinxing myself but the car has not did this again. SALEM1912 may have hit it on the head. I redid a the ground wire he was talking about and it has been good. I may have spoke to soon we will see. Thank you
[Re: burdar]
#503460
11/09/09 11:25 PM
11/09/09 11:25 PM
mopar376d
Russiaville, IN
So far so good. Has not happened again.
