Tm7 or M1 #502730
10/21/09 11:01 AM
10/21/09 11:01 AM
still waiting on 684
K
Kiner Offline OP
Kiner  Offline OP
K
Tm7 or M1 which one do you think flows better?
4150 carb.Steel headed 440.big valves.
Re: Tm7 or M1 [Re: Kiner] #502731
10/21/09 12:46 PM
10/21/09 12:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
M1 may flow a little better but it is really hard to beat a TM7 so it may come down to the almighty $$$$
Re: Tm7 or M1 [Re: Dodgem] #502732
10/21/09 12:48 PM
10/21/09 12:48 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Tm7 or M1 [Re: Kiner] #502733
10/21/09 01:45 PM
10/21/09 01:45 PM
an8sec70cuda Offline
Of those 2 choices, the M1. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Tm7 or M1 [Re: an8sec70cuda] #502734
10/21/09 02:52 PM
10/21/09 02:52 PM
K
Kiner Offline OP
Kiner  Offline OP
K
I have them both.Looking for some feedback.
Thanks.
Re: Tm7 or M1 [Re: Kiner] #502735
10/21/09 06:35 PM
10/21/09 06:35 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
M1
Re: Tm7 or M1 [Re: jake4cars] #502736
10/21/09 06:38 PM
10/21/09 06:38 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Is the TM7, what used to be called the Tarantula?? I remember the carb sat out of square on BBC engines..
Re: Tm7 or M1 [Re: minivan] #502737
10/21/09 09:02 PM
10/21/09 09:02 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Yep tarantula. carb mounting is not crooked like on a rat motor
Re: Tm7 or M1 [Re: Dodgem] #502738
10/22/09 01:31 AM
10/22/09 01:31 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I asked this question a couple of years ago on this forum. Guys told me if I had it already then run it!!! They were a hell of a good manifold considering they're 35+ years old, but there are a lot better designs now.
We ran the TM7 on an old 68 stock pistoned 440 in a 3700# Challenger, and thru 2 1/4 tailpipes it'd run 12.30's on a good day!!
Like I say, don't go out and buy one on compulsion....but run it if you got it.
Re: Tm7 or M1 [Re: superwrench] #502739
10/22/09 01:38 AM
10/22/09 01:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have found the TM7 and the M1 both work good and there is not much difference in performance between them on an average street/strip eng. The Holley Street Dominator works about the same and some feel it is even better on a mild street/strip build. I use the Holley SD because it fit under my hood with room to spare and I like it better then the TM7 and the M1 as it has good low end for a single plane. But I would not hesitate to run which ever one of them 3 intakes I had as they are so close in performance. Ron
Re: Tm7 or M1 [Re: Kiner] #502740
10/22/09 05:18 AM
10/22/09 05:18 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think they flow close all right. I'd run the TM7 just because it's old and that makes it cool.
Sheldon
Re: Tm7 or M1 [Re: RUNCHARGER] #502741
10/22/09 09:07 PM
10/22/09 09:07 PM
K
Kiner Offline OP
Kiner  Offline OP
K
Thanks everone.
Or I could go back to the Team G and the Dominator.???
