Re: motor home motor questions
[Re: CrazyRocker70]
#502388
10/20/09 08:56 PM
10/20/09 08:56 PM
Posts: 15,487 Florida
scratchnfotraction
IIRC,the 413 heads are not worth that much for performance a steel crank will have the thin damper on the crank a thick bullet nose damper (like mine,79 MH) is a cast crank cast crank 440 is just as good as a steel crank 440,IMHO could be some one out there that wants the 413 engine..and the other 440s as well,they dont make them any more and getting few and far between,IMO I could use one of the flat rubber tranny mounts myself
[Re: CrazyRocker70]
#502390
10/20/09 09:16 PM
10/20/09 09:16 PM
scratchnfotraction
I geuss to the right person it would be a little gem look at the heads on the 440s also,some are better than other mine had the 452 some could be the odd one that use the penut plugs I am not sure on any of it,I am just doing up my first 440 from a MH in an 85 truck most MH 440s have the front sump pan unless the are the truck/van type RV mine was a 60 foot winnybaygo 1 1/2 ton chassis,with a short shaft 727 with a 4" u-joint and 1 1/4" round caps...I shouldnt brake that one good luck
[Re: scratchnfotraction]
#502391
10/20/09 10:56 PM
10/20/09 10:56 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
FWIW, some of the MH BB's had 8 bolt cranks too...
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: 69DodgeCharger]
#502394
10/22/09 09:44 AM
10/22/09 09:44 AM
scratchnfotraction
that damper is for cast crank only mine has the 727 short shaft that was on it from the rv not sure if the tc has been weighted or not..have not looked yet I dont see any thing wrong with any good 440,run what you brung mine also has the 452 heads which is good also IMO,shaving 60 foot of motor home off and putting it in a 85 truck with 3.91sg will be a boost for a stock 440 if you ask me
