post your bb with hp manifolds builds #502225
10/20/09 05:43 PM
10/20/09 05:43 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, just for fun looking for some bb builds with hp manifolds. Looking for hp, ETs and combos. Just curious to see what kind of power can be made with these. THANKS
Re: post your bb with hp manifolds builds [Re: 70VcodeCoronetRT] #502226
10/20/09 06:47 PM
10/20/09 06:47 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
440 .030 over flat tops with 0 deck, 452 heads with exhaust side ported with .080 cut off the deck with felpro composite gaskets (i believe .029 squish) torker II edelbrock intake with 800 holley dp, 484/284 hydraulic "purple shaft" fairbanks small flash convertor 4.56 gear with a 30x9 radial slick Bone stock 68 dodge coronet with everything in it went a best of 12.70 @ 107 with HP manifolds, original h pipe mufflers and tailpipes. It wasn't real fast but i thought it was quick at the time
Re: post your bb with hp manifolds builds [Re: prochargedhemi] #502227
10/20/09 08:47 PM
10/20/09 08:47 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I am putting my GTX together with HP manifolds. It is basically a stock build of a 70 440 that I re-ringed and put a resto purple stick in. It will have a 2.5" X pipe exhaust and probably dyno-max muffs. It has a 4 speed behind it and an 8 3/4 w/ 2.76 sure-grip. It isn't running yet, so we'll see how it runs. Not going to be a drag car by any means, planning on sway bars front/rear with performance more built around handling than go-fast ability.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: post your bb with hp manifolds builds [Re: 70VcodeCoronetRT] #502228
10/21/09 08:35 AM
10/21/09 08:35 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Not exactly the HIGHEST performance manifold out there but it's the best that will fit in my engine bay...
Re: post your bb with hp manifolds builds [Re: 70VcodeCoronetRT] #502229
10/21/09 08:41 AM
10/21/09 08:41 AM
Crowley,TX
70Duster360 Offline
super street
70Duster360  Offline
super street
Crowley,TX
This is the best build-up I've seen w/manifolds, done by AndyF.
When you click the link, go to True Tales, Stroker.
http://www.arengineering.com/articles/articleframe.html
Re: post your bb with hp manifolds builds [Re: 70Duster360] #502230
10/21/09 12:57 PM
10/21/09 12:57 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Here ya go....
Re: post your bb with hp manifolds builds [Re: 70VcodeCoronetRT] #502231
10/21/09 12:58 PM
10/21/09 12:58 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
look no further than FAST racing
