Headlight Delay Relay for 1970
#502038
10/20/09 11:55 AM
10/20/09 11:55 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
What exactly did it do? How was it wired up? Would you shut off the ignition and headlights in a sequence for the headlights to remain on with the doors open and then close after a duration of time passed?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Headlight Delay Relay for 1970
[Re: Pyper70]
#502040
10/20/09 12:22 PM
10/20/09 12:22 PM
Posts: 308 Turneffe
BJohnson
Turneffe
[Re: BJohnson]
#502041
10/20/09 12:24 PM
10/20/09 12:24 PM
Pyper70
Athens, Greece
Hmmm...Interesting.....So it was for E-Bodies as well? Thanks for the help guys....I had this relay sitting around from my 70 Charger build and I found it sitting in a box....Wonder why I never installed it....
[Re: Pyper70]
#502042
10/20/09 12:52 PM
10/20/09 12:52 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
optional in all Bodies... I think also to A bodies.
But don't really know on 68/69 Chargers, since doors are vacuum instead electrical. I'm not sure if you can control vacuum with electrical impulse on these cars being Vacuum swiths is a mechanical action parallel with the electrical section when you push the rocker, and not an electrical impulse what makes the vacuum works
