Need an engine compartment Picture #501781
10/19/09 10:01 PM
10/19/09 10:01 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
I am looking for a picture of the right side of the upper engine of a a 1971 charger roadrunner cuda or challenger with a 383 holley four barrel, 4-speed manual car with a heated air air cleaner. In particular need to see the wiring from the two wires of the Idle solenoid one to the distributor vac advance and one to the engine harness. I have the correct solenoid and advance but there has to be some sort of short harness to connect them together and to the engine harness. Hope someone can help. THANKS!!!!
Re: Need an engine compartment Picture [Re: 340cpe] #501782
10/20/09 10:34 PM
10/20/09 10:34 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
I was hopeful that someone had a 71 B or E body with the 383 4-speed that I could get a look at. It is no problem wiring it to work if I have to, I just have all the proper parts and wanted it to look right when done.
Re: Need an engine compartment Picture [Re: 340cpe] #501783
10/21/09 07:24 PM
10/21/09 07:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Need an engine compartment Picture [Re: Challenger 1] #501784
10/21/09 09:45 PM
10/21/09 09:45 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks for he pics of the cars challenger1 but I am looking for a picture of the right side of the engine where the distributor vac advance and the idle solenoid connect. There must be some short harness that connects them and I do not have it so I wanted a picture of this area of the engine compartment so I could duplicate one. My research shows that this set up was used in 71 B&E bodies with a 383 4-speed car. If you have an original 71 with this set up I would surely appreciate a picture of this area of your engine compartment. Thanks
Re: Need an engine compartment Picture [Re: 340cpe] #501785
10/21/09 10:44 PM
10/21/09 10:44 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Just an FYI, my 71 W200, 383, manual trans, had that same stuff on it, so someone with a truck might be able to help with wiring pics too.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Need an engine compartment Picture [Re: phantomx] #501786
10/21/09 10:54 PM
10/21/09 10:54 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks for the info phantomx that may help. I did not even think of a truck nor did I know that they were similar. Thanks
Re: Need an engine compartment Picture [Re: 340cpe] #501787
10/22/09 01:55 AM
10/22/09 01:55 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Do you have both wires coming off the distributor?
Re: Need an engine compartment Picture [Re: 340cpe] #501788
10/22/09 07:31 AM
10/22/09 07:31 AM
Cincinnati, Ohio
Cincinnati, Ohio
I was just giving you a Glad you like my pictures.
Re: Need an engine compartment Picture [Re: BJohnson] #501789
10/22/09 10:02 PM
10/22/09 10:02 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thanks bjohnson for the reply. YES I have the wires coming off of the distributor and the ones attached to the solenoid, but they are not long enough to connect, nor are they the proper ends to connect if it were long enough. so there must be a short harness of some sort between them. It is the proper solenoid (NOS) and the proper advance (NOS) and of course the proper holley carb. If you can help further I would appreciate it. Thanks again
Re: Need an engine compartment Picture [Re: Challenger 1] #501790
10/25/09 09:55 PM
10/25/09 09:55 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
With no where else to really turn I am calling out for help on this one, one last time. I would really like to wire this the proper appearing way. Thanks Again for any help possible.
Re: Need an engine compartment Picture [Re: 340cpe] #501791
10/25/09 11:13 PM
10/25/09 11:13 PM
Shoreline, Washington
72roadrunnergtx Offline
I can’t help you with the requested picture but be sure to check page 8-153 in the 71’ FSM, shows a female bullet type connector on a short lead paralleled off the dark blue field wire at the alternator. This provides the ign. power to the retard solenoid with it's other lead running to the insulated cap on the carb mounted curb idle solenoid to provide the ground to retard the timing ~5 degrees or so at idle. The picture above of the OEM retard/advance unit shows the original leads used to make the connections. Should be relatively easy to recreate to whatever length you need, it would appear.
There is a good shot of the 71’ Holley 4160 leads on page 14-67.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Need an engine compartment Picture [Re: 340cpe] #501792
10/26/09 08:43 AM
10/26/09 08:43 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
maybe these will help
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Need an engine compartment Picture [Re: MOPARMIKE69] #501793
10/26/09 08:43 AM
10/26/09 08:43 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
passenger side
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Need an engine compartment Picture [Re: MOPARMIKE69] #501794
10/26/09 08:44 AM
10/26/09 08:44 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Drivers side
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Need an engine compartment Picture [Re: MOPARMIKE69] #501795
10/26/09 08:46 AM
10/26/09 08:46 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
another
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Need an engine compartment Picture [Re: MOPARMIKE69] #501796
10/26/09 10:23 PM
10/26/09 10:23 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
72 roadrunner I did see that in the FSM but wanted to wire it factory correct not just put a wire connector in there if that is not what was used. I do have a numbers matching car and am doing my best to it get back to original. Moparmike the picture of the passenger side of the engine may just do it if the air cleaner was removed. Thanks everyone for there help.
