Re: Aluminum in my oil filters, 440-1 spring pockets?
[Re: sg66mopar]
#500768
10/18/09 11:25 PM
10/18/09 11:25 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Yep Its no secret that those cast valve pockets are a joke... Get a aggressive aluminum Burr and grind those off flush and ad some cups
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: rebel]
#500771
10/19/09 12:24 AM
10/19/09 12:24 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
when i asked indy to supply my heads machined for cups they said. 'nah nah, spring locators are the in thing, much better than cups'. those guys just dont know their sh..! of course they failed just as yours have. cups are soooo much better & control the springs harmonics better too.
Laziness. They just wanted to sell you cylinder heads, not have to do any extra work.
[Re: cupcake]
#500773
10/20/09 12:06 AM
10/20/09 12:06 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i had the same problem assembled motor forgot crack pipe in eng block wont do that agein
can you elaborate a bit more on this please? are you saying you left your "crack" pipe in the engine block during assembly? i hope thats not what i'm reading.
[Re: galen]
#500775
10/20/09 02:46 PM
10/20/09 02:46 PM
as sorry as some Indy stuff is --namely the pushrods the valves are fine--BBB in Argentina makes them and they will do fine--if a valve head ever comes off it was because something was beating on it ---those valves are fine--it is a good idea to hit the tips at the lock groove with some sandpaper BEFORE you try and pull them through the guides--they are prone to making a tiny lip there after running --NO big deal BBB is one of the most modern valve mfg's in the world and I bet one of the biggest---pay more for valves and sleep better if you want to but no need Yea yea others "flow " better BIG deal
Locaters are fine and the crazy cool fast stuff like your hot circle track heros ( the 9200 RPM guys ) use them vs. cups in most apps---The deal on the Indys is that where the pocket was machined it leaves a razor thin edege that SHOULD have been hit with a grinder BEFORE assembly but hey--we are talking about Indy here---
and besides the aluminum is probably from your rockers eating themselves away on the shafts If they are aluminum--check there first
