Re: 25 MPG with a 408 ??? Yup!!
[Re: hooziewhatsit]
#500586
10/18/09 10:14 PM
10/18/09 10:14 PM
Posts: 1,061 New Mexico
dmerc
New Mexico
Here's the recipe: Magnum heads with tight quench .030. Bowls opened up. Stock valve job. Wiesco dished pistons Mopar Performance M1 Dual plane intake Roller cam Compcams #20-000-9 506 lift 216 intake 224 exhaust duration. Mopar orange box. 340 HP manifolds with a TTI 2 1/2 inch exhaust system. Distributor that I recurved for timing all in at 2000 RPM. This is a big one: Thermoquad 850 carb. Best carb I've tried and I've tried them all. 700R4 Chevy trany with converter lockup. But any overdrive trans would work. 3.23 8 3/4 rear end Aluminum radiator with electric fans. Fans don't operate at anything over 40 MPH so you gain at least 1 MPG with that mod.
[Re: dmerc]
#500588
10/18/09 10:25 PM
10/18/09 10:25 PM
RapidRobert
What is your (measured) CR and what gas?
[Re: dmerc]
#500592
10/18/09 10:38 PM
10/18/09 10:38 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
You did it! I'm going to be optimistic and say you will hit somewhere between 12.8 and 13.2 seconds in the quarter. Now let's see.... Skinny tires, lower it, and 3.08's; sounds like 27mpg to me?
Mo' Farts
Moderated by "tbagger".
[Re: Mr.Yuck]
#500597
10/21/09 08:11 PM
10/21/09 08:11 PM
Posts: 1,546 Seattle, WA
375inStroke
Special needs person
Seattle, WA
why build a 408 to run 13.5? Who care about mpg...make it run right and you might be able to pull a 13.0.
13.0 MPG?
[Re: 375inStroke]
#500598
10/21/09 08:51 PM
10/21/09 08:51 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
I'd be interested in the MPH when you run it. Sounds like a good street combo. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: phantomx]
#500599
10/21/09 09:01 PM
10/21/09 09:01 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I'm assuming this was mostly, if not all highway??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: phantomx]
#500600
10/21/09 09:07 PM
10/21/09 09:07 PM
dmerc
New Mexico
I'll be taking the Duster to the drags to see what it will do on Sat. I'll report back. Hope I don't blow it up!!
[Re: CJK440]
#500601
10/21/09 09:17 PM
10/21/09 09:17 PM
dmerc
New Mexico
All highway except for a little drag race with a mustang on the freeway. (guess who won?)
