Page 1 of 5 1 2 3 4 5
25 MPG with a 408 ??? Yup!! #500582
10/18/09 09:29 PM
10/18/09 09:29 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
After a little fooling with timing and carb low speed circuit I got 25 MPG with my Duster. It can be done guys!! Next thing is to get to the track. I expect it to run 14.5's at 5000 ft which will be equivalent to 13.5's at sea level. Car has never run better and I'm just at 30 total timing with 15 degrees of vacuum advance added on.
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500583
10/18/09 09:46 PM
10/18/09 09:46 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
Dang. Id be happy if I could get my 70 cuda with a 340 to get even 15 mpg city :/
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500584
10/18/09 09:50 PM
10/18/09 09:50 PM
repost your specs. I want some.
Re: 25 MPG with a 408 ??? Yup!! [Re: RapidRobert] #500585
10/18/09 09:55 PM
10/18/09 09:55 PM
hooziewhatsit Offline
So throw that same set up in my W200, with the aerodynamics of a brick, I wonder what it would get
Re: 25 MPG with a 408 ??? Yup!! [Re: hooziewhatsit] #500586
10/18/09 10:14 PM
10/18/09 10:14 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Here's the recipe:
Magnum heads with tight quench .030. Bowls opened up. Stock valve job.
Wiesco dished pistons
Mopar Performance M1 Dual plane intake
Roller cam Compcams #20-000-9 506 lift 216 intake 224 exhaust duration.
Mopar orange box. 340 HP manifolds with a TTI 2 1/2 inch exhaust system.
Distributor that I recurved for timing all in at 2000 RPM.
This is a big one: Thermoquad 850 carb. Best carb I've tried and I've tried them all.
700R4 Chevy trany with converter lockup. But any overdrive trans would work.
3.23 8 3/4 rear end
Aluminum radiator with electric fans. Fans don't operate at anything over 40 MPH so you gain at least 1 MPG with that mod.
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500587
10/18/09 10:22 PM
10/18/09 10:22 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What speed are you driving at to get that mpg? With that rear gear and overdrive, you must be keeping the rpm very low...
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500588
10/18/09 10:25 PM
10/18/09 10:25 PM
What is your (measured) CR and what gas?
Re: 25 MPG with a 408 ??? Yup!! [Re: DaytonaTurbo] #500589
10/18/09 10:26 PM
10/18/09 10:26 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Running 65 to 70 MPH. At 70 I'm turning about 1800 RPM. I'm running a 28 inch tire too. 275/60 -15
Re: 25 MPG with a 408 ??? Yup!! [Re: RapidRobert] #500590
10/18/09 10:32 PM
10/18/09 10:32 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Calculated CR is 10.5 to one. Dynamic effective compression is 8.5 to one. Cranking pressure was 155 PSI. I always run 87 octane but on this last gas mileage run I put in 91 octane. I really don't know if it made any difference.
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500591
10/18/09 10:34 PM
10/18/09 10:34 PM
Thanks bro
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500592
10/18/09 10:38 PM
10/18/09 10:38 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
You did it!
I'm going to be optimistic and say you will hit somewhere between 12.8 and 13.2 seconds in the quarter.
Now let's see.... Skinny tires, lower it, and 3.08's; sounds like 27mpg to me?
Mo' Farts
Moderated by "tbagger".
Re: 25 MPG with a 408 ??? Yup!! [Re: Grizzly] #500593
10/18/09 10:41 PM
10/18/09 10:41 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
If I gear any taller I'll be able to feel the individual power pulses on the highway! LOL!!
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500594
10/18/09 11:29 PM
10/18/09 11:29 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Is this your everyday driver
Re: 25 MPG with a 408 ??? Yup!! [Re: ademon] #500595
10/19/09 07:06 AM
10/19/09 07:06 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
It's an every day driver. Now I have to complete the project. The body (except for engine bay) is ugly and the interior is shot. It's kind of a sleeper except for the big tires. Dog dish hub caps. Nothing fancy.
Re: 25 MPG with a 408 ??? Yup!! [Re: dmerc] #500596
10/19/09 08:10 AM
10/19/09 08:10 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why build a 408 to run 13.5? Who care about mpg...make it run right and you might be able to pull a 13.0.
Coming soon!!!!
Re: 25 MPG with a 408 ??? Yup!! [Re: Mr.Yuck] #500597
10/21/09 08:11 PM
10/21/09 08:11 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
13.0 MPG?
Re: 25 MPG with a 408 ??? Yup!! [Re: 375inStroke] #500598
10/21/09 08:51 PM
10/21/09 08:51 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I'd be interested in the MPH when you run it. Sounds like a good street combo.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: 25 MPG with a 408 ??? Yup!! [Re: phantomx] #500599
10/21/09 09:01 PM
10/21/09 09:01 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I'm assuming this was mostly, if not all highway??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 25 MPG with a 408 ??? Yup!! [Re: phantomx] #500600
10/21/09 09:07 PM
10/21/09 09:07 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Travis..
I'll be taking the Duster to the drags to see what it will do on Sat. I'll report back. Hope I don't blow it up!!
Re: 25 MPG with a 408 ??? Yup!! [Re: CJK440] #500601
10/21/09 09:17 PM
10/21/09 09:17 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
All highway except for a little drag race with a mustang on the freeway. (guess who won?)
