stainless steel valve cover gasket? #499170
10/17/09 12:21 AM
10/17/09 12:21 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I have this idea of getting 1/16" stainless steel valve cover gaskets made for my Predator heads.
That way I could just get them coated with Neoprene rubber & have a reuseable gasket
paper gaskets run $30 a set shipped for these silly heads and I need a cost effective alternative since I have solid lifters
do you guys think my idea would work or do you forsee any flaws?
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: stainless steel valve cover gasket? [Re: RylisPro] #499171
10/17/09 12:29 AM
10/17/09 12:29 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
working on that idea now. need to cut the molds then I can have the steel blanks laser cut. Not sure of the cost effectiveness yet.
Re: stainless steel valve cover gasket? [Re: RylisPro] #499172
11/09/09 03:45 PM
11/09/09 03:45 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
My gaskets came back in stainless steel
Now I just have to coat them in Neoprene
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: stainless steel valve cover gasket? [Re: RylisPro] #499173
11/09/09 04:36 PM
11/09/09 04:36 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
COOL idea!!
Re: stainless steel valve cover gasket? [Re: RylisPro] #499174
11/09/09 09:09 PM
11/09/09 09:09 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
here are pics on the head itself
wondering if I could get away with just a thin coat of silicone to seal it?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: stainless steel valve cover gasket? [Re: RylisPro] #499175
11/09/09 09:23 PM
11/09/09 09:23 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
why not have the valve cover o-ringed?
Re: stainless steel valve cover gasket? [Re: prochargedhemi] #499176
11/09/09 09:32 PM
11/09/09 09:32 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I called Williams Performance about that and
they said it was too late since they already welded the valve covers up.
The grooves needed to be cut before the welding.
this was my next best compromise
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: stainless steel valve cover gasket? [Re: RylisPro] #499177
11/09/09 09:47 PM
11/09/09 09:47 PM
Temperance, MI
P
P
Temperance, MI
i gunna go out on a limb here and say that you should be able to have that done at any machine shop
Re: stainless steel valve cover gasket? [Re: prochargedhemi] #499178
11/09/09 10:14 PM
11/09/09 10:14 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
tried that too
problem is my valve covers have mounts for coils
I told you my idea was
it was just easier this way
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: stainless steel valve cover gasket? [Re: RylisPro] #499179
11/10/09 03:24 AM
11/10/09 03:24 AM
San Diego
formula S Offline
formula S  Offline
San Diego
tried that too
Even better,now they have a place to bolt a plate to for tooling. So if they say they cant do it, they're not trying very hard
