challenger ta vent line ?'s #498956
10/16/09 07:21 PM
10/16/09 07:21 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
i just installed all the new lines for my ta resto
. the vent line came with the line that connects to the fill tube and makes a U turn thru the trunk pan, it then curves and looks like it either goes thru a wide opening in the frame rail, or it goes into a small hole in the frame rail and dead ends there. it dont make sense for the later because the package had 4 hose clamps, 2 for the fill tube and the other 2 should be for the other end of the line, but i have no idea where it would connect to. or the supplier shorted me a long tube that should go to the front of the car and connect to the carbs. any help is very much appreciated. thank you.
Re: challenger ta vent line ?'s [Re: kingkt] #498957
10/16/09 07:30 PM
10/16/09 07:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
From memory, no N95 on your fender tag right?
So, the line enters the frame rail with nothing on the end.
Re: challenger ta vent line ?'s [Re: Alaskan_TA] #498958
10/16/09 07:42 PM
10/16/09 07:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Deleted to avoid any confusion, the right answer is below.
Re: challenger ta vent line ?'s [Re: kingkt] #498959
10/16/09 07:50 PM
10/16/09 07:50 PM
IMGTX Offline
IMGTX  Offline
Maybe these will help too.
Re: challenger ta vent line ?'s [Re: Alaskan_TA] #498960
10/16/09 07:59 PM
10/16/09 07:59 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
thanx guys, appreciate your help. without this forum, id be wayyyyy behind in the resto. thanx again.
Re: challenger ta vent line ?'s [Re: kingkt] #498961
10/16/09 08:09 PM
10/16/09 08:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I was wrong, it goes in the small hole. I should have walked out & looked at my car.
