Which RB Stroker Kit? #498659
10/16/09 03:20 PM
10/16/09 03:20 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I'm looking at a couple kit for my mostly stock looking street car. Which would you go with?
1. Mancini - 4.125 Eagle Crank, 6.7 Eagle H beam rods (2.20 journal, .990pin), Diamond Dish pistons (4032 alloy). Kit is $1450 unbalanced.
2. 440 source - 4.250 crank, 7.1 rod, Ross Dish piston (2618 Alloy). $1897 balanced
3. Any other good deals/options?
Price looks pretty good on the Mancini kit is something wrong with that setup?
Thanks,
Steve
Re: Which RB Stroker Kit? [Re: srunge55] #498660
10/16/09 03:44 PM
10/16/09 03:44 PM
AndyF Offline
AndyF  Offline
Hughes Engines is fairly close to you'll save on shipping. Muscle Motors also has some stroker kits for sale and so does Best Machine. Just a matter of finding the one that fits your needs the best.
You did start out by reading my book didn't you? $20 up front for the book can save you a lot later on in the process.
Re: Which RB Stroker Kit? [Re: AndyF] #498661
10/16/09 03:54 PM
10/16/09 03:54 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I do have your book Andy and have read most of it. Very good read - congratulations. You seem to favor the 4.25 stroke (or so it seemed to me). Any particular reason other than cubes? I will look into some of the other kits but the 4.125 Mancini kit seems to be a very attractive price compared to what I have seen so far.
I did see an earlier post where you were talking about running HP manifolds on your 470. I thought you said you were trying the same on a 512. How did that turn out, did you use the .528 MP cam on that also?
Steve
Re: Which RB Stroker Kit? [Re: srunge55] #498662
10/16/09 05:05 PM
10/16/09 05:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks,
Steve
4.125 stroke and a 6.700 rood , that doesn't look right .
Do yourself a HUGE favor and DO NOT PAY for a balanced kit , have it balanced by the local shop doing your work. A cheap balance job is just that , a cheap balance job .
Re: Which RB Stroker Kit? [Re: srunge55] #498663
10/16/09 05:36 PM
10/16/09 05:36 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
Steve
I'm kinda in the same situation...deciding on a 512 or a 528. I'm gonna use stock manifolds, also. I'll wait to see what Andy says..
Re: Which RB Stroker Kit? [Re: srunge55] #498664
10/16/09 05:39 PM
10/16/09 05:39 PM
that Mancini kit looks like it uses chevy rods.
that 440 source kit... 7.1 rod? geez.. how far up the piston does the pin sit?
cant see that lasting very long.
Re: Which RB Stroker Kit? [Re: JohnRR] #498665
10/16/09 06:52 PM
10/16/09 06:52 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Oops, does a 6.760 rod sound right? I see Best Machine selling crate motors with this same rotating assembly.
440 source will knock off $150 w/o the balance job. So it would be $1747. Mancini's kit looks better to me at $1450. 440 source has a 4.15 stroke kit but it uses a Mopar Rod journal. I thought the BBC journal was the way to go these days.
Re: Which RB Stroker Kit? [Re: srunge55] #498666
10/16/09 08:26 PM
10/16/09 08:26 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Not positive, but...I believe you're comparing a 440 source kit that includes rings and bearings to a Mancini kit that doesn't
Re: Which RB Stroker Kit? [Re: Bill MeLater] #498667
10/16/09 08:44 PM
10/16/09 08:44 PM
Wisconsin USA
Wisconsin USA
Just checked....It does come with rings and bearings....That's a sweet price
Re: Which RB Stroker Kit? [Re: srunge55] #498668
10/16/09 09:34 PM
10/16/09 09:34 PM
AndyF Offline
AndyF  Offline
Steve
My new low deck 512 motor does have HP manifolds but it has a small hyd roller camshaft rather than the .528 flat tappet. It made good power on the dyno but I haven't installed it in my car yet.
Yes, with a 440 block I'd recommend the 4.250 stroke crankshaft and Chevy rod journals with Chevy rods. 6.800 or 7.100 long rods should be fine. Either setup is very nice and the piston has plenty of room for a conservative ring stack.
If you shop only on price then you'll be getting the least expensive items on the market. That includes the rings, bearings, bolts, etc. That is fine if that is what you want but don't go that way if you're planning on making a bunch of power. Lots of ways to go, just make a plan and understand what you're doing and you'll be fine.
Re: Which RB Stroker Kit? [Re: srunge55] #498669
10/16/09 09:34 PM
10/16/09 09:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That sounds better , but a longer rod would be better to make the piston package smaller and less rotating mass .
sounds like the eagle crank is using a mopar sized big end , the BBC big end provides more clearance .
As far as which is better , I'll spare the board from the abuse I'll get from the ..
Re: Which RB Stroker Kit? [Re: JohnRR] #498670
10/16/09 10:00 PM
10/16/09 10:00 PM
whats the benifit of running a 4.250 crank, 7.1" rod on a street engine?
thats pin must be so far up the piston I can't see it lasting 5k on a street engine.
or am I wrong?
Re: Which RB Stroker Kit? #498671
10/16/09 11:26 PM
10/16/09 11:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
or am I wrong?
The compression height with a 7.1 rod & a 4.25 stroke is still 1.48 Plenty of street motors are considerably shorter... Obviously the shorter piston is considerably lighter... AndyF does seem to favor the 6.8 rod combo...
Re: Which RB Stroker Kit? [Re: 1_WILD_RT] #498672
10/16/09 11:38 PM
10/16/09 11:38 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm at the point where I'm ready to place my order. After all my research, running Desktop Dyno, and reading Andy's book, I'm leaning towards the complete 440Source 512 kit. I was going to go with the 528 but the 512 seems to make more power no matter what I throw at it. This is the RB version of course. The 499 would be my next choice. Either one is using a .055 overbore.
Re: Which RB Stroker Kit? [Re: 1_WILD_RT] #498673
10/17/09 01:01 AM
10/17/09 01:01 AM
AndyF Offline
AndyF  Offline
or am I wrong?
I went 6.800 long rods on the motor I built for the book becuase there were a lot more choices for pistons and rods then. But since then, some more vendors have come along with both pistons and rods so if I was building a motor today I'd probably take another look at it.
SCAT has cranks now that weren't available a year ago, K1 has cranks that I didn't know about when I wrote the book. Compstar has some new rods available, etc.
Even with the 7.10 long rods and the 4.250 stroke the piston is still tall enough to be very conservative. The rod ratio is good, the rod is long enough to keep the piston skirts up off the crankshaft counterweights, etc. All around a great combo. No reason a motor like that wouldn't go 100,000 miles if you built it like an OEM engine.
The slightly shorter 6.80 rod also works just fine. There are a few oddball rods out there such as 6.850 and 6.900 but you'll probably need semi-custom pistons if you run those.
Re: Which RB Stroker Kit? [Re: AndyF] #498674
10/17/09 01:15 AM
10/17/09 01:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Glad to hear that.. I'm finishing up my 7.1 rod 505 & while I feel it's gonna be a reliable street combo it's always been in the back of my head that you choose to go with the 6.8 rod... I don't think the rod ratio differance is of much consequence & I know enough guys running shorter pistons that I felt it would be fine.. I felt trading piston height for rod length was gonna reduce the bobweight & in my mind it was a good trade-off...
Re: Which RB Stroker Kit? [Re: 1_WILD_RT] #498675
10/17/09 05:47 AM
10/17/09 05:47 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Going in your B body vert Randy??
Re: Which RB Stroker Kit? [Re: minivan] #498676
10/17/09 11:36 AM
10/17/09 11:36 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Maybe...
Re: Which RB Stroker Kit? [Re: 1_WILD_RT] #498677
10/17/09 11:40 AM
10/17/09 11:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I was looking around since I just spun number 4...Hughes has some nice kits and are only a few bucks over 440 source. Seems like 440 source has a complte balanced kit for the cheapest. I'll make up my mind once the machine shop tells me how bad the damage is.
Coming soon!!!!
