63 dart...can i put the 76 dart disk brakes/rear end in
#498618
10/16/09 12:55 PM
10/16/09 12:55 PM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
the girl is looking at getting an early A body 63 or 65 can you swap the late a body disk brakes and rear end in it? im just looking to update it for saftey reasons thanks
Re: 63 dart...can i put the 76 dart disk brakes/rear end in
[Re: cogen80]
#498620
10/16/09 01:50 PM
10/16/09 01:50 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
You will need the later arms also if you are going to big bolt pattern brakes.Rocky
Chrysler Firepower
[Re: coronet1966d]
#498623
10/16/09 02:10 PM
10/16/09 02:10 PM
therocks
Niles , Ohio
Yes the ball joints are different from SB to BB patterns.You will need upper and lower.I think DrDiff has a setup to run the small ball joints with the disc spindle.The rear you will have to measure to see if widths are the same.Rocky
Chrysler Firepower
[Re: not_a_charger]
#498625
10/16/09 03:05 PM
10/16/09 03:05 PM
RapidRobert
The 8.25 rear is a direct bolt-in?
An A body one yes, just need the 8.25/8&3/4 (3") ubolts and the corresponding shock plates. EDIT save your original ebrake cables as you MIGHT need em for a correct fit rather than the 8.25 ones.
