Page 1 of 3 1 2 3
Okay fabricators... time to make stuff happen!! #498515
10/16/09 12:16 PM
10/16/09 12:16 PM
Tracy CA
rabid scott Offline OP
"You're Where?"
"You're Where?"
Tracy CA
This weekend I'm going to make the Dakota frame fit the 1940 Dodge Coupe body.
I will be using the whole Dakota frame, as the original frame is almost beyond use. I may use a small rear section of the original frame to cap the Dakota frame and provide a place to mount the rear bumper.
I wanted to see what you guys thought of the way I was going to shorten the frame. I need take out about 4", I will double check the measurement before I make any cuts.
See the picture to see how I'm thinking about cutting it and putting it back together.
After welding it back I will plate the inside of the frame, and then box it for good measure.
Thoughts? Comments? Death threats?
Re: Okay fabricators... time to make stuff happen!! [Re: rabid scott] #498516
10/16/09 01:15 PM
10/16/09 01:15 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
It will work the way you have it layed out but we have also just cut straight down and welded it back together and then boxed the inside of the frame. (check out the links below)
a little while ago on my COE PU project I used a cut off wheel and separeted the frame at the factory weld and cut off 30" and brought the back half to the factory area and put it back together, it looks like it came that way, I tend to OVERKILL so I will probably plate a little to the inside of the frame. Ron....
https://board.moparts.org/ubbthreads/show...e=1#Post5422308
http://rides.webshots.com/album/300985977tszAFe
Re: Okay fabricators... time to make stuff happen!! [Re: Mopar Ron] #498517
10/16/09 04:15 PM
10/16/09 04:15 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
This would be my biggest concern getting your two cuts down the length of the frame both straight so you could match things back up when you are done. That means you have to make four cuts on each side of the frame rail straight (top and bottom of each section you plan on keeping) then you have to bring the two sections of frame back and square keep it all square. It will work but I can see a lot of trimming happening unless you have some seriously steady hands or quality equipment.
What Ron did seems easier and with the addition of plates and boxing the frame you should have a solid result (with good weld penetration obviously).
Re: Okay fabricators... time to make stuff happen!! [Re: bohmer2] #498518
10/16/09 05:00 PM
10/16/09 05:00 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
if you are just going to shorten 4" what about moving the rear axle forward and just cutting off the back of the rails
Re: Okay fabricators... time to make stuff happen!! [Re: NoFrills] #498519
10/16/09 05:16 PM
10/16/09 05:16 PM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
I understand the concern with making multiple straight cuts, but I think I could manage those.
Cutting it straight would definately be easier, though.
We'll see I guess, just kind of thinking and weighing my options.
The frame has an arch.... here's the best pic I could find...
Re: Okay fabricators... time to make stuff happen!! [Re: rabid scott] #498520
10/16/09 07:13 PM
10/16/09 07:13 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I like your plan for the lap joint. It is more work but will be stronger than a butt joint.(The rear kick in my frame is butt jointed) I say go for it!
Arno
Re: Okay fabricators... time to make stuff happen!! [Re: B1arno] #498521
10/16/09 07:51 PM
10/16/09 07:51 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I agree with Ron. Straight cut it at the factory seam, move the rear section ahead 4" and reweld. Plate the inside and put some grade 8 bolts through it in a couple of places if it makes you feel better. Very simple operation. It will be harder to make body mounts. Don't worry it will be strong enough.
Re: Okay fabricators... time to make stuff happen!! [Re: AeroMonte] #498522
10/16/09 08:36 PM
10/16/09 08:36 PM
moparx Offline
moparx  Offline
all of the ideas will work. use whichever you feel most comfortable with. measure 3 times, cut, tack, re-measure, finish weld.
Re: Okay fabricators... time to make stuff happen!! [Re: moparx] #498523
10/18/09 04:55 PM
10/18/09 04:55 PM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
It worked out beautifully!
I didn't take as many pictures during the putting it all together as I wish I had, but I was somewhat preoccupied with the welding and such.
More here on my webpage:
Merciless Frame Hacking
I'm anxious to build the body mounts and get this thing going!!
Re: Okay fabricators... time to make stuff happen!! [Re: rabid scott] #498524
10/18/09 05:00 PM
10/18/09 05:00 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Great job!
Re: Okay fabricators... time to make stuff happen!! [Re: B1arno] #498525
10/19/09 08:24 PM
10/19/09 08:24 PM
moparx Offline
moparx  Offline
very good grasshopper !
Re: Okay fabricators... time to make stuff happen!! [Re: moparx] #498526
10/20/09 01:18 AM
10/20/09 01:18 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
nice job,,what was the wheel base of the dakota frame to start with ?
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Okay fabricators... time to make stuff happen!! [Re: rabid scott] #498527
10/22/09 04:37 AM
10/22/09 04:37 AM
San Jose,CA
migsBIG Online happy
YouTube is my go-to news source
migsBIG  Online Happy
San Jose,CA
Looks like you did your homework. Looks to be a natural cut and weld job. Boxing the welds afterwards is a good idea.
Re: Okay fabricators... time to make stuff happen!! [Re: fstfish66] #498528
10/22/09 01:55 PM
10/22/09 01:55 PM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
Thanks guys!!
I've already got a pair the front body mounts fabbed up and tacked on, not 100% if they are where they are going to stay, height wise. Looking much better though!
Last night I took the leaf springs and rearend out, I need to move the leaf springs under the frame, they interfere with the body subframe and I don't want to cut into that.
After I get the leafs springs shuffled around, I can build the rear body mounts and set the rear of the body down over the frame, which should drop the car pretty heavily.
After I get all that stuff done I figure I'll take a few more update pictures, because it will really start to look like a car!
There are three different wheel bases, mine was the shortcab longbed which was 123.9 inches.
Re: Okay fabricators... time to make stuff happen!! [Re: rabid scott] #498529
10/24/09 12:27 AM
10/24/09 12:27 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
cat wait to see more pics,,,car porn pleaseeee
2015 cherokee
2013 R/T classic
Re: Okay fabricators... time to make stuff happen!! [Re: fstfish66] #498530
10/27/09 02:31 PM
10/27/09 02:31 PM
Ontario, Canada
dodge41 Offline
dodge41  Offline
Ontario, Canada
Re: Okay fabricators... time to make stuff happen!! [Re: rabid scott] #498531
10/28/09 10:50 AM
10/28/09 10:50 AM
ccarson Offline
ccarson  Offline
I have an ongoing dakota drag project.
we didnt shorten the frame, but we did box the inside of the frame from the factory boxed section to the rear bumper with 1/8", it added some weight but did it ever stiffen up the frame before it was a flexi flyer now it's like a battleship !!
I wouldnt hesitate to cut the frame straight, bevel,butt weld and box the frame on the inside just make sure you secure the frame. our's was fixtured up on a surface plate and allowed to cool it was stitch welded over a two day period to control heat induced warpage.
Re: Okay fabricators... time to make stuff happen!! [Re: dodge41] #498532
10/29/09 12:08 AM
10/29/09 12:08 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
nice job,,,
2015 cherokee
2013 R/T classic
Re: Okay fabricators... time to make stuff happen!! [Re: fstfish66] #498533
10/30/09 11:15 PM
10/30/09 11:15 PM
orangeville,PA
P
plmczy Offline
plmczy  Offline
P
orangeville,PA
hey scott, looking good any updates?
Re: Okay fabricators... time to make stuff happen!! [Re: plmczy] #498534
11/03/09 02:04 PM
11/03/09 02:04 PM
Tracy CA
"You're Where?"
"You're Where?"
Tracy CA
Progress has been a little slow the last week, but I have been busy in the time I've had...
I got the rear springs knocked out and the spring hangers knocked off the side of the frame, which took longer than I expected.
I made new front spring hangers and with the Dakota's leaf springs and aftermarket rear shackles I got the 8 3/4" rearend mocked up under there. I haven't welded anything yet, but I think it's going to work out nice.
I took a couple pictures last night, but didn't get a chance to get them off the camera.
I also found a rear swaybar in the shed that I bought years ago that was advertised fitting an E-body but it didn't, it looks like it might be a nice fit for this project!
Page 1 of 3 1 2 3
