Steering Box interchange from 70 Cuda to 74 Cuda Box #498254
10/15/09 09:11 PM
10/15/09 09:11 PM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
I went to get a warranty exchange on my steering box at the autoparts store, and turns out a1 Cardone is completely out of cores for the 70 cuda power steering box.
Will the 73-74 box fit?? According to the Firmfeel website, the later box is actually an upgrade for the old one. Is it a direct swap? Do I need to change out the pitman arm to the later version? Is the valve body a direct fit?
Thanks!
Re: Steering Box interchange from 70 Cuda to 74 Cuda Box [Re: Cudalord] #498255
10/15/09 09:18 PM
10/15/09 09:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yes it will work , but requires the pitman arm from the newer model
