valves for indy sr,s
#498113
10/15/09 05:15 PM
10/15/09 05:15 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i keep wearing out the intake valves in my sr,s. ![](/ubbthreads/images/graemlins/frown.gif) they are the ones supplied with the heads.is there a better longer lasting valve for these heads? they are 2.19". where would i get them?
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: valves for indy sr,s
[Re: Old School]
#498114
10/15/09 05:20 PM
10/15/09 05:20 PM
Manley has them---call Marsh Performance 336 752 2879 for your best deal
[Re: Old School]
#498116
10/15/09 05:46 PM
10/15/09 05:46 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I use Ferrea. They flow better and I think they are better quality. Just ask for the Indy replacement valves and they'll be right.
Brian Hafliger
[Re: Old School]
#498118
10/15/09 09:46 PM
10/15/09 09:46 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
wheres the best place to get them? also,is it worth it to go up to 2.25"? its on a : 500" 13.4 cr 272/276 .750" solid roller. sr 295 cnc about how much more cfm?
First, what's wearing out on the valves? The stems, the tip or is the head tuliping? What kind of seals are you running on there and how much guide clearance do you have? I think it's worth going to the larger valve, provided there's some portwork to go along with blending in the larger valve job. Average CFM increase? That I can't tell you but I did get a set of Perf RPM heads to flow 345 with a 2.250 valve and a max wedge port. So I can only imagine how much better the SR's would respond to it.
[Re: dodgeboy11]
#498119
10/15/09 10:31 PM
10/15/09 10:31 PM
care to share a picture of that?
[Re: dodgeboy11]
#498120
10/15/09 11:49 PM
10/15/09 11:49 PM
Old School
Virginia Beach, VA
it is the stems that keep wearing out.i use the viton seal. i thought i read a post awhile ago from dwayne porter about having to do something about the guides in theese heads. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Old School]
#498122
10/16/09 03:16 AM
10/16/09 03:16 AM
Posts: 753 San Diego, CA
brktracr
super street
super street
San Diego, CA
I second the Ferrea, Brian put them in my SR's and I've been extremely happy with the heads and the work he did on them.
1.298 60 ft
6.001 1/8 mile
114 mph
9.52 1/4 mile
140.87 mph
@ 3110 lbs
[Re: brktracr]
#498123
10/16/09 08:01 AM
10/16/09 08:01 AM
Posts: 162 Greentown Indiana
moparmxz
Greentown Indiana
I,ve run the sr heads with no excessive stem wear in 8 years.Granted i run a small cam(.620),maybe you have some kind of geometry problem. ![](/ubbthreads/images/graemlins/Twocents.gif)
Randy Brough
1967 440 Dart S/P
6.37 106mph best eighth 3150 lbs
[Re: moparmxz]
#498124
10/16/09 01:06 PM
10/16/09 01:06 PM
Old School
Virginia Beach, VA
my cam is a .661 solid roller.i use indys 1.6 rocker arm kit with a roller tip.the pushrods are the right length.i have this exact combo on three motors.all of them wear the stems to fast. im rebuilding one now and im trying some 1.7 t&d,s.if that fixes it,i will swap the others over too.
[Re: Old School]
#498126
10/16/09 03:19 PM
10/16/09 03:19 PM
Life ain't as complicated as folks make it out to be and Andy is right--Chevy .100 long and there ya go from anywhere--I think DairyMart has those but the Manleys from Todd will do the trick-- and I bet cheaper than Ferrera which are good too. ![](/ubbthreads/images/graemlins/thumbs.gif)
